5.1 Speaker System Question
Discussion in 'AV Receivers & Amplifiers' started by Bheng, Jun 19, 2005.
  1. Bheng
    Bheng
    I have a Yamaha RXV657 and 5.1 speaker system (Polk Audio). What's the appropriate decoder/effects that I need to use when watching movies and/or listening to music to appreciate true surround sound? Thanks!
  2. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Connect your DVD to the amp via Coax/Optical digital, assign the audio input for the DVD as Auto - this way the amp will pick the audio medium that is sent from the DVD - remember when you start the DVD to use the menu to select the audio sound you want to use i.e. DD/DD5.1/DTS
  3. Bheng
    Bheng
    I'll try that tonight OZ...Thanks again...
  4. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +21
    By the way how do you rate your 657???
