5.1 Speaker Placement Help - TV in corner
Discussion in 'Home Cinema Buying & Building' started by donsmith753, Aug 9, 2013.
  1. donsmith753
    donsmith753
    Dec 21, 2008
    19
    I've recently moved into a new home and I'm looking for some help with speaker placement. The main issue I'm having is that my tv is in the corner of the room, flanked by a large window on one side and a fireplace on the other.
    I've attached a couple pictures of the room (excuse the mess) and will try and get a rough sketch added shortly if required.
    Unfortunately can't reposition any of the furniture so need to make the most of what's there.
    Any help/guidance would be greatly appreciated, thanks.
  2. donsmith753
    donsmith753
    Dec 21, 2008
    19
  3. donsmith753
    donsmith753
    Dec 21, 2008
    19
  4. donsmith753
    donsmith753
    Dec 21, 2008
    19
    [​IMG]
    [​IMG][​IMG]
  5. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    Do you already own the speakers you aim to put in here? Are you considering wall mounting or stand mounting? I think whatever you do you'll be selecting a the 'least worst' solution.
    Given the very constrained space you have around the TV, you may want to go for a phantom centre (4.1 system)? Another option may be a soundbar?
  6. donsmith753
    donsmith753
    Dec 21, 2008
    19
    I already own them. Here's a link to what I've got: HKTS 9 - Harman Kardon
    I was going to wall mount the rear two above my sofa. It's the front two & centre I'm struggling with.
    Open to using stands if that would work best.
  7. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    I think some wall brackets and positioned one next to the window and the other by the fireplace is the bat you can do. Try the one next to the fireplace above it (e.g. on the mantle) and to the side to see how much influence the sound is changed by being against the fire surround.
    Given the fairly narrow spread of the front pair, and the limited space, I suggest you try out the sound without it (set up as phantom centre or 4.1 which sends the centre channel to the front speaker pair).
  8. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,760
    What are all the things in the fireplace?
    Couldn't you replace the TV to there?
  9. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,535
    The Borders
    +3,481
    A 2.1 system or a Soundbar (set to 3-beam mode) + Sub would work best.
    Joe
