Quantcast
5.1 sound on games does it exist ?
F
FoxyMulder
Does 5.1 channel sound exist ive upgraded to a RGB scart and 5.1 channel optical out but Buffy the Vampire Slayer and Dead or Alive 3 on the XBox still only play as dolby pro logic i have a good system a sony DTS and Dolby Digital Amp strb930 set to auto format decode helpppppppp wots up ?
S
spikeyboyo
Yes 5.1 does exist on the Xbox - i can confirm games like Halo, Sega GT 2002, Project Gotham Racing do do 5.1 sound.
Im not sure if DOA3 and Buffy support 5.1 sound though - you will need to check the back of the boxes to see if it says Dolby Digital sound (5.1)
Spike
Kevo
And some are in anamorphic WS too.
Just bought my xbox and two of the games (Rocky and Sega GT 2002) are in WS much to my surprise.
CarlB
I have both Buffy and DOA3 on the XBox and can confirm they decode as 5.1 on my system. Sounds like you may not be passing the 5.1 signal, have you checked the audio section of the XBox dash and 'Enabled' DTS and DD?
lechacal
You don't need an RGB SCART. You need the lead with the optical audio out that you plug into the digital amp. 5.1 sound can only be carried on digital leads (optical/coax), not analogue - that's why you only get stereo/prologic.
F
FoxyMulder
I have the optical lead connected but havent checked the audio section of the X box thats obviously not been set right so i'm sure when i recheck it and re-set it everything will be fine thks for ur help folks
Similar threads
