5.1 sound on 360?
Discussion in 'Xbox Forums' started by Mr Miaowgi, Aug 19, 2005.
  1. Mr Miaowgi
    Mr Miaowgi
    Aug 7, 2005
    334
    Hertfordshire
    +29
    http://shop.gameplay.co.uk/webstore/genre.asp?platform=XB360&parent=PERIPH&genre=PERI10
    The above link shows the cables available for the 360 on release? None of these allow for 5.1 sound into your 5.1 system like an optical ouput.
    I am very worried as just got a new Pioneer 5.1 system which I cant see how I am going to get into my 360 now.
    The only spare port on my 5.1 system is the optical in (line 2) and on top of that my tv has no component so am going to need a scart lead. The advanced scart lead on the above site looks like the current one where the optical output is included in the lead which would be ideal.
  2. benlonguk
    benlonguk
    I would have thought it'll be like the current xbox AV cables, you'll supply the optical lead and plug it in to the xbox lead. It will have optical out don't worry about it.
  3. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    I think i've found the answer for this one
    Game have the 'COMPONENT HD AV CABLE' listed as an accessory
    http://shop.game.net/ViewProduct.aspx?cat=11273&mid=327030
    Features:
    The all-in-one solution for high-definition and standard TVs
    High-definition gaming output of 720p or 1080i
    Progressive-scan DVD playback in 480p
    Dolby Digital 5.1 Surround Sound output
    Component (Y, Pr, Pb) highdefinition video output
    8-foot-long shielded cable
  4. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    Infact, if you check Bigwilli's link above,
    gameplay have now added 5.1 to the description of the HD cables on their site too
  5. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    Why are people worying about this. Its definately going to have optical out in one shape or form. Its likely to be on the Av block as with the current xbox - plus the deluxe pack actually comes with this cable.
