Hi Guys,
If you had a rectangular room.. sofa about 6" away from the rear, large screen at the far end of the room length-ways, 5.1.4 setup which option would you choose for your 'side surrounds' ?
I did look at the KEF T-101s for the side surrounds for Option 1, but I don't think they'll give me the frequency response that will match the other speakers well plus they're not timbre matched to the Q-Acoustics front bed layer and I don't want to replace the lot at the moment.
If I wanted to go with a 'nicer' bookshelf type side surround like the 1010i, 2010i, 3010i etc. I'd have to go slightly ahead of MLP due to the sofa being almost against the back wall and a doorway being directly to the left of the MLP.
I did read that Dr Floyd Toole did a lot of testing and found side surrounds slightly ahead of the MLP actually gave a more immersive sound-stage (although I can't find the exact paragraph in his book at the moment as I have a copy here) so I did think maybe going for Option 2 wasn't such a bad idea
What do I have now? I actually have a 5.1.2 setup with the 2 side surrounds currently plugged into the rear of the .4 on the ceiling, which for 5.1 content is fine but obviously it kills the Atmos effect having the side surrounds up there on the same level as the front 'height' channels
Limitations? There's no room to put the bookshelf speakers on stands at 90 degrees to the sofa as you'd trip over the Side-Left walking into the room (and the Mrs would be upset
) I did think about putting the left speaker just above the door frame of MLP at 90 degrees, but as I've only got about 8.5ft ceilings it would be firing in the right direction to the MLP but it would only be about 18" from the 'height layer' and not give that ear level separation I'm looking for on the bed layer. Sofa is unable to come forwards anymore as there's a soft along the left wall as well and you wouldn't have room to walk unto the room (circle back to the Mrs not being happy again
This is the sort of layout I have (with the door beautifully penned in red
Yellow = Option 1 - Shoe-horned in there.
Blue = Option 2 - Bookshelf (on floor stand or bracket)
Green = Not really an option in my mind as it's too close to the height layer that I'm trying to move back to .4 from .2
Thoughts?
- Option 1) Q-Acoustics 7000LR type speaker at 90 degrees to MLP (maybe just a tad behind). (I actually have some Q-Acoustics QAV Surround speakers still, the BMR type but I think the consensus these days is their response isn't great compared to 'normal' speakers.
- Option 2) Q-Acoustics 3010 / 3010i speakers but slightly in-front of the MLP, probably at about 65-75 degrees
Thoughts?
