5.1 Passthrough on Windows Media Player?
AndyH
I'm setting up my HCPC and I'm using a Soundblaster MP3+ (external USB).
This is working great except for one thing, I can't persuade Windows Media Player to output 5.1 sound. In WinDVD I need to enable the S/PDIF passthrough option to get DD / DTS through the optical connection.
Trouble is, I can't find a similar option for Windows Media Player.. is this possible?
It isn't a great loss if it isn't, but it'd be nice to try the new hi-def WMV9 trailers properly.
Cheers,
A.
K
Kramer
Nope, not possible. WM9 trailers or films don't have DD or DTS but are encoded using a MS codec. Only way to pass this to a receiver via S/PDIF is if using an nForce 2 mainboard - has realtime DD encoding.
You can pass the 6 analogue channels but it's not that convenient for many :(.
AndyH
Excellent, thanks for the quick reply. Your explanation is spot on, it makes perfect sense why this isn't possible.
The MP3+ doesn't have the full compliment of analogue outs, so even that option is a non starter with this device.
No problem, DD / DTS from WinDVD was the important thing for me. If anyone is interested in a little tip, DTS passthrough on this device only works if it is in Digital Only mode.
Thanks again,
A.
F
freeflap
thanks for this topic. I have an ASUS nforce2 mobo and am using the asus coax spdif output. works great. I can output using spdif with wmvhd but only comes out as PCM stereo. How do I enable realtime DD output to listen to 5.1 wmvhd?
also, anyone have info on more media using the wmvhd format?
thanks
b
james.miller
if you have the asus a7n8s DELUX, then it would be:
soundstorm control panel >> speaker setup >> dolby digital encoding
If you don't have the deluxe with soundstorm, then you can't do it.
T
Toekiller
Have you tried Ac3 filter?
I got dd out of a wm9 encoding.
F
freeflap
i have the -vm version, micro atx. therefore no soundstorm. What if I buy an audigy or similar. Will that card convert spdif output to dd or dts?
thanks
b
Too Tall
I'm thinking of getting a Shuttle 45 case which has soundstorm, but I read some where that the DD encoding only encodes all of the 5.1 channels from the stereo fronts. Does anyone know if this is true. Or do you get proper 5.1 DD when inputting WM9 5.1?
Cheers,
Stuart.
james.miller
it will encode any material into 5.1 - thet includes multi channel games and videos.
F
freeflap
which will? My -vm asus mobo does not. Are you referring to the audigy?
thanks
b
james.miller
no sorry, i was refering to Too Tall's question above my post. As for your problem, the soundstorm is current the only solution that can encode into 5.1
F
freeflap
so, even the audigy or any other PCI add in card will NOT work to output 5.1 wmvhd? Rats.....
b
K
Kramer
Via S/PDIF, no. Only "Soundstorm" will encode for passthrough via S/PDIF to a processor/receiver.
Most soundcards will output 5.1 through analogue outputs i.e. 6 individual co-axial connections to suitable amp/receiver.
:smoke:
T
Toekiller
So what am I getting out of my wmvhd copy of ' the transporter'
It says dolby digital on my receiver ;)
Spidif through Audigy.
tom_nieto
Toekiller, you're getting the DD track on the DVD.
The DD processing on the nForce 2 is pretty cool, but it's not that necessary. If you've got pro logic 2 on your amp you'll be better using that for stereo movies, I find the voices to be much more realistic. For music it can be good or bad, depending on what your taste is. I had it on for a while but I've got it off for the moment.
Jeff
Originally posted by Kramer
Nope, not possible.
Not quite true, the hardware and software already exists to do this, it just isn't readily available yet.
All you need is a Pioneer AX10ai AV amp and the Microsoft driver.
Too Tall
Guys,
My question seams to have been slightly misunderstood. I'll make it clearer (or not as the case maybe):
I realize that soundstorm can encode anything into DD5.1. What I was asking was that I had heard that it just sent the stereo front pair to all the speakers. Even when given a 5.1 sound track it will down mix it to 2 channel and then put the left channel to the 2 left speaker front as back, the right channel to the 2 right speakers front and back, and then mix them to give the centre and sub. Basically giving you 5.1 stereo is this true? (to be honest if this is true I'd be better off sending PCM stereo to my Denon A1SR and let it do the work). Or does it put each channel from a 5.1 (say WM9) sound track to the correct speaker in DD5.1?
Cheers,
Stuart.
james.miller
it encodes it into 5.1DD. it wouldnt BE 5.1DD unless every channel was capable of producing its own signal. If the fronts were just doubled up to the rears, then it would only be 2.1.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
