5.1 or 6.1 or 7.1 which one ?
Discussion in 'Home Cinema Speakers' started by Pinoy, Feb 23, 2005.
  1. Pinoy
    Pinoy
    Planning to bulid my HT system but bit confused which one to go for, 5.1 or 6.1 or 7.1 ?
    Is there a big difference in sorround sound between each of them ?
    Is it worth to spend 1 or 2 more extra speakers ?
    Are all DVD disc maximise each set up ?
    Help ! ! !
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Part of it depends upon space as well- do you have room for all the speakers.?
    I may be wrong, but to get 6.1 the dvd needs to be dts or your av amp needs es/ex processing (try a search).
    There are some pics of 5.1, 6.1 and 7.1 on www.mordauntshort.com to give you an idea of speaker configuration.
  3. Pinoy
    Pinoy
    Thanks . . .
    My room I think is considered medium room. I am planning to get denon avr 3805 and a denon dvd 2910 in which I think it will do most of the format.
