5.1 on modded xbox
Discussion in 'Xbox Forums' started by brightonrvf, Jul 8, 2005.
  1. brightonrvf
    brightonrvf
    Sep 26, 2004
    1,776
    Brighton/Glasgow
    +429
    Hi all i am having getting 5.1 through my xbox, i have the hi def pack and optical but it the amp is only seeing the front channels. I am running avalaunch and says in the settings menu it is enabled for surround but not for dts or ac3, will this make any difference?
    I am playing from the hdd, not too sure if this makes any difference.
    Any thoughts appreciated.
    BRVF.
  2. CrossyX
    CrossyX
    Feb 15, 2005
    2,787
    83
    +160
    U need to check in the original menu (Microsoft one) and check that DD or DTS is selected in there (not Prologic) and no it wont make a diffrence running games from the HD aslong as the game supports DD.
  3. brightonrvf
    brightonrvf
    Sep 26, 2004
    1,776
    Brighton/Glasgow
    +429
    Brilliant many thanks!!!
  4. brightonrvf
    brightonrvf
    Sep 26, 2004
    1,776
    Brighton/Glasgow
    +429
    I dont suppose you have your xbox networked do you??? I am having problems with my router connection
