5.1 Movies
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Bling Bling, Oct 7, 2003.
  1. Bling Bling
    Bling Bling
    Just got Sky + installed yesterday and very pleased with it, so far....can anyone point me in the direction of a list / programme guide, either on the web or via the programme guide which lists the movies that are going to be broadcast in 5.1 ?
    Cheers.
  2. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    It tells you in the Sky Guide.
    Apparently its a bit unreliable though.
  3. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    Aylesbury...where the Ducks live!!
    i seem to think that sky premier 1-3 are widesrceen DD enabled tho it varies from moive to movie....if u info the moive it will have DD for dolby digital or DS for dolby surround
  4. NicolasB
    NicolasB
    Oct 3, 2002
    5,804
    Emily's Shop
    +520
    The "info" function in the EPG should tell you. In the top right hand corner "DS" means "Dolby Surround", "DD" means "Dolby Digital 5.1".
  5. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    is there an echo ;)
  6. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Haven't Sky sorted out the 5.1 problem with the new software update which was supposed to fix Dual Record and a whole load of minor OS issues?
    When it does work is the sounds as good as you'd get from a DVD?
  7. leesbriggs
    leesbriggs
    They havn't sorted the premier 1,2 and 3 sound problem on v2 boxes and dual record is not with us yet :(
  8. leesbriggs
    leesbriggs
    Oh, and as for sounding as good as DVD, I can't tell the difference!
  9. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    sound wise its what it says on the tin...DD..but i will say that it seems to need a bit more volume then my dvd sound tracks
    i've got the old V1 box with working digital:D
  10. leesbriggs
    leesbriggs
    So turn the volume up in the sky menu?!!
  11. NicolasB
    NicolasB
    Oct 3, 2002
    5,804
    Emily's Shop
    +520
    I would have thought that the volume in ther Sky menu would only affect the Sky+ box's analogue outputs. I don't think it would modify the digital output stream. Especially not for DD - it would have to decode the original Dolby Digital stream, increase the values, and then re-encode the stream before outputting it, all in real time. That's far from easy.
  12. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    Mr Briggs it only effects DD movies....everything else has the same level....must be how sky incorparate the DD soundtrack into their bandwidth
  13. leesbriggs
    leesbriggs
    OK, fair enuff, but the volume in the sky menu does adjust the output going to the amp.
    Also, I don't notice a volume level difference on mine.
    Just trying to be helpful!!
