Question 5.1 Left 75W, centre 150W, right 75W - does this match?
Discussion in 'What Speakers Should I Buy?' started by Queens Pawn, Aug 23, 2018.
  1. Queens Pawn
    Queens Pawn
    Jun 2, 2011
    184
    28
    +33
    I have 2x 75W bookshelf speakers with 1x 5 1/4" mid/woofer each,
    and 1x 150W centre with 2x 5 1/4" mid/woofers.
    Can these be put together to form a front sound stage, given that the centre is twice as powerful as the left and right?
  2. Gasp3621
    Gasp3621
    Jan 16, 2014
    1,873
    116
    +917
    The center channel with dual mid-bass drivers often has higher power handling figure and if you were to look those numbers make sure they are both printed as RMS (continuos). Though i would be less worried about those, more what speakers / models are you using there? Are they different brands / models, give us more information.
  3. gibbsy
    gibbsy
    May 17, 2007
    14,516
    3
    Cwm Cynon, De Cymru
    +8,361
    Model consistency is important across the fronts. As above what are the speaker model.
  4. Queens Pawn
    Queens Pawn
    Jun 2, 2011
    184
    28
    +33
    They are AE100i bookshelf speakers which I've had for 20 years, and a centre AE107c which I bought recently - so same range, and the mid/woofers look identical. (Acoustic Energy)
  5. gibbsy
    gibbsy
    May 17, 2007
    14,516
    3
    Cwm Cynon, De Cymru
    +8,361
    Yes I would say they will work as the front soundfield. Any differences in volume will be solved by the receivers EQ system.
  6. Queens Pawn
    Queens Pawn
    Jun 2, 2011
    184
    28
    +33
    thanks! I will proceed ..
