5.1 in a diamond shaped room
Discussion in 'Home Cinema Speakers' started by hencole, Mar 11, 2003.
  1. hencole
    hencole
    What are peoples opinions on a 5.1 set up in a diamond room setup. The TV is in one corner of the room, so this makes placing the front right and left speakers quite tricky. Also I'm concerned the shape of the room will be problematic to the overall quality.
    Thanks,
    Henry
