5.1 Home cinema system <£400
Discussion in 'Home Cinema Buying & Building' started by kevcfc, Feb 8, 2009.
  1. kevcfc
    kevcfc
    Apr 13, 2007
    +3
    Hi, as the title suggests, we're after an all in one home cinema kit to replace our ageing, cheapo Lenoxx Sound HT-500.
    It is to go with our Samsung LE40F86 LCD TV, and we will be using it with a Technomate 6900HD sat receiver, Sly+HD & a Wii. If it doesn't come with a DVD player then you can add that to the list;)
    We'd prefer a Samsung (just to go with the TV, but it doesn't have to be) with Tallboy speakers, & with a built in DVD player too, although £300 ish without one wouldn't be a problem.
    Been reading quite a bit about the Sony HTS-F1300, which seems to be well recommended, and looks the part. Would this be OK, or is there a system just as good as this with a DVD player? Looked at a few others to, including some Samsung's, but I'm really not sure what I should be looking for exactly:rolleyes: The last thing I want to do is spend a small fortune on this, only to find I could have got a much better piece of kit for less.
    Hope that makes sense, & that I'm not asking to much. Thanks for reading:D
  2. Pontiac
    Pontiac
    Jul 5, 2007
    737
    28
    London
    +64
    Sony DAVDZ260 is worth a look at. Don't be put off by it's cheapness. It's a very good performer.
  3. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    Something like the htss1300, htsf1300, htsf1200, htddwg800, yamaha av63+ would be a good choice...
    All amp & speaker packages with lots of inputs for other equipment...
    They all take LPCM over hdmi, so combined with a blu ray player that can decode hd audio, you'll get dolby true hd / dts hd ma from blu rays...
    A blu ray player such as bdp-s550 will do that...
  4. kevcfc
    kevcfc
    Apr 13, 2007
    +3
    Thanks, just had a quick look at that but SWMBO insists on the tallboy speakers. Is their an equivalent with the tallboys?
    I've got until Feb 23rd to get something, that's when they come to fit the Sly HD, and I don't want to be taking the TV off the wall again after that cos it's a pain:nono:
    Regards:)
  5. kevcfc
    kevcfc
    Apr 13, 2007
    +3
    Thanks, I'll take a look at them:smashin: Maybe I can persuade her indoors to get the blu ray....:clap:
  6. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    Well if tallboys are a must, look at the htsf1200 and htsf1300. Both pretty much exactly the same except for cosmetic differences. The former is rarer but cheaper.
    As they are amp & speaker systems you can easily connect lots of different stuff up to them. You have 3 hdmi inputs, 2 optical, 1 digital coax, and a few phono inputs.
    They will decode dolby digital and dts, and also take decoded uncompressed audio (LPCM) over hdmi. I have the 1200 and i'm more than pleased with it.
    The thing with dvd player systems is they have a lack of inputs for other stuff, plus you can't get rid of the dvd player without losing your surround system. Imho it's worth paying a bit more for something more versatile, with better features. It means it will last longer, if it's compatible with all the latest tech (ie blu ray and hd audio).
  7. kevcfc
    kevcfc
    Apr 13, 2007
    +3
    The only problem now is finding it in stock, it's like finding rocking horse manure:censored:
    I'll persevere and see if anything turns up, thanks for the help:smashin:
  8. markie
    markie
    Jul 30, 2004
    310
    +20
    If you find anywhere with stock at not an inflated price, let me know, as I'm having the same issue !
  9. kevcfc
    kevcfc
    Apr 13, 2007
    +3
    Bit the bullet & got a Sony HT-SF1300 from Pixmania :clap:. Not had chance to set it up yet but, just to be sure, can someone tell me if I'm right thinking:
    1) Sly HD box connects to SF1300 via HDMI
    2) Technomate HD box connects to SF1300 via HDMI
    3) TV can connect to SF1300 via optical cable, to allow surround sound via Freeview
    4) SF1300 connects to TV via HDMI
    Would this allow all the above to operate via the surround sound kit?
    Cheers,
    Kev.
  10. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    sky don't output 5.1ch over hdmi, so you need an optical cable from sky to the amp. Video from sky can go direct to tv with hdmi.
    don't know anything about these! Does it output surround sound over hdmi? If so, then yes.
    yep.
    only if you're feeding video to the amp which needs to be passed on to tv.
    Hope that helps / makes sense! :smashin:
  11. kevcfc
    kevcfc
    Apr 13, 2007
    +3
    Cheers, that's made things a bit clearer:smashin:
