Quantcast
5.1 headphones with home cinema system
johnhy
im looking at getting 5.1 surround sound headphones nothing too fancy or expensive.
ive seen the medusa ones and like others it says you need dvd player with 5.1 phono outputs. i have a toshiba 42hk home cinema system so the 6 speakers connect to this via speaker cable i think there are no 5.1 phono outputs is theer any way round this?
either with different headphones or does the headphone jack on my DVD player have the 5.1 in that anyone any ideas thanks
B
bobbypunk
no but the elat-dv100 has a dolby digital decoder but not DTS built in and sells for just £60 ish.
