5.1 headphones with home cinema system
Discussion in 'Headphones, Earphones & Portable Music' started by johnhy, May 13, 2004.
  1. johnhy
    johnhy
    Dec 8, 2003
    1,811
    Glasgow
    +101
    im looking at getting 5.1 surround sound headphones nothing too fancy or expensive.
    ive seen the medusa ones and like others it says you need dvd player with 5.1 phono outputs. i have a toshiba 42hk home cinema system so the 6 speakers connect to this via speaker cable i think there are no 5.1 phono outputs is theer any way round this?
    either with different headphones or does the headphone jack on my DVD player have the 5.1 in that anyone any ideas thanks
  2. NicolasB
    NicolasB
    Oct 3, 2002
    6,675
    137
    Emily's Shop
    +1,046
    If you look 7 or 8 lines farther down this forum you will find a thread entitled "5.1 headphones" which discusses this question in some depth.
