5.1 headphones for xbox360
Discussion in 'Headphones, Earphones & Portable Music' started by wash-dog, Jan 15, 2008.
  1. wash-dog
    wash-dog
    Apr 7, 2006
    5
    Hi ya ..
    This is my first post ..
    I would like to know which is the best 5.1 headphones for the xbox 360, and what is the best way to connect them to the xbox elite.. Do you go usb or jack plug.... Any help would be helpful...
    many thanx..:lease:
  2. Proctimus Prime
    Proctimus Prime
    Oct 9, 2007
    52
    +3
    Sharkoon X-Tactic ive heard are very good. Just plug straight into your TV's headphone jack.
  3. wash-dog
    wash-dog
    Apr 7, 2006
    5
    cheers m8.. will give them a look...:thumbsup::thumbsup:
  4. torr1x
    torr1x
    Dec 5, 2007
    222
    +16
    Hiya. Firstly, whats your budget, and do you want a mic built in ? How good do you want the sound quality ?
    Best route ive found, if you dont mind not having a mic, is optical out from your elite to a surround decoder that does dolby headphone, then plug any decent set of headphones in, or use wireless ones.
    http://www.avforums.com/forums/showthread.php?t=454776
    See above for more info. I have the Pioneers, love them. If you're not worried too much about sound quality but want a mic then look at the Tritton Ax360, or sharkoon.
  5. wash-dog
    wash-dog
    Apr 7, 2006
    5
    Thanxfor your help torr1x ... I will give them a look.. cheers m8..
  6. torr1x
    torr1x
    Dec 5, 2007
    222
    +16
    No problem :thumbsup:
