5.1 front & back
Discussion in 'Home Cinema Speakers' started by kerraig, Jan 10, 2003.
  1. kerraig
    kerraig
    My 5.1 set up at the moment has Acoustic energy AE 1's for the front left & right and Mission M71's for the rear. Thing is, the mission M71's are biwirable, so I was wondering if anyone had any knowledge of these speakers, what would be the advisable set up. My centre is a mission too so for reasons of tone it probably makes more sense to swap em round..
    P.S. is biwiring as easy as just passing a 2nd set of leads through the same outputs on the amp or is there more to it than that?
  2. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Hi there! Just read this thread:
    AV Forums > AV Hardware > General Hardware > Bi wiring (and cables), what a load of ******** (long)
    Not sure how to make it click-on-able... but it should tell you all you need to know about bi-wiring! :)
  3. kerraig
    kerraig
    cheers.
  4. Dom H
    Dom H
    If the AE 1's sound better than the mission, I'd give phantom centre a whirl.
