5.1 for xbox
Discussion in 'Xbox Forums' started by clarkyb, Feb 2, 2005.
  1. clarkyb
    clarkyb
    Feb 2, 2005
    264
    28
    +58
    hi, my friends dad gave me a 5.1 amp with speakers and sub
    on my attempt to rig it to my xbox i found it had no optical socket and no scart on my amp, and the only 2 leads i can find in game for connecting to an amp are optical and scart
    so is there any way i can have 5.1 sound with this kit? btw i am currently linked up so i get 2.1 sound and sub
    thanks
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,197
    In a secret location with Jennifer Lawrence
    +7,072
    What you need is the Xbox advanced Scart Cable.
    It has RGB scart for the TV and an optical outlet for the amp.
  3. clarkyb
    clarkyb
    Feb 2, 2005
    264
    28
    +58
    thanks,
    but i said i have no optical socket in my amp
    :lease:
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Sounds like it doesn't have an in-built decoder. You need an AV reciever with optical input that'll then have 6 outputs into your amp.
  5. clarkyb
    clarkyb
    Feb 2, 2005
    264
    28
    +58
    thank you very much
    but how much will one of those cost
  6. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    If your 5.1 amp has no optical then it must surely have a coaxial socket, usually orange phono on back of amp. . I dont believe they make a lead from the Xbox to coaxial digital so thats maybe out the question AFAIK.
    As for picture theres really no need to take video signal through amp unless u wish to free up sockets on TV. But if you do need to im sure a Game store or similar will have an Xbox lead to Svideo or Composite.
    Matt
  7. clarkyb
    clarkyb
    Feb 2, 2005
    264
    28
    +58
    THANKS
    so as i understand it there is no way i can get 5.1 sound without getting a separate decoder box????? and the cheapest i have seen those are around £50-60 :confused:
  8. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    I got mine for £15 or something, no way near £60 !!!
  9. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    I would imagine a search on ebay or on the classifieds here may turn up something. I believe I have seen 5.1 systems minus the speakers for less than £30, not sure where though.
    Not knowing the particulars about the equipment you have been given I would imagine your better off finding a cheap 2nd hand system which has SVideo capabilities and an Optical connection. IMHO
    If some other member knows of another solution im sure they will add their tuppence worth :thumbsup:
    Matt
    Matt
  10. womble9
    womble9
    Dec 28, 2003
    944
    +64
    Like Malone says if your amp hasn't got a Toslink digital in then it will more than likely have a coaxial in which will be an orange phono socket although in my experience it's far more common to be the other way round. If it does turn out to have the coaxial in then you can (assuming you're ok with this kind of thing and don't mind voiding your warranty) mod your x box using these instructions http://www.xbox-scene.com/articles/digital-output.php as i chose to do with mine. Not too sure about the Toslink diagram but the coaxial deffo works just fine and the bits will cost about 50 pence :) .
  11. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    2,719
    +392
    Maplin do an Optical to Coaxial convertor if that's any good?
  12. clarkyb
    clarkyb
    Feb 2, 2005
    264
    28
    +58
    thanks for the help everyone the maplin thing is just what i need (i hope) :smashin:
  13. womble9
    womble9
    Dec 28, 2003
    944
    +64
    Either way you'll be glad you did it, the surround effect on some games are superb.
