5.1 bypass & Pioneer Blu-ray
Discussion in 'AV Receivers & Amplifiers' started by orange55, Jun 8, 2009.
Tags:
  1. orange55
    orange55
    Feb 27, 2006
    827
    London
    +397
    Having played and read quite a bit on these forums about the Pioneer Blu-ray players, LX51, LX71 & LX08 and there anolog output, is anyone able to post there settings for the speaker output levels to get correct bass through the Tag 5.1 bypass?
    Currently I have:
    Speakers set to Large
    Bass set to Bypass
    Front, Center & Surround at -2db give or take
    Subwoofer at +6db
    Has anyone had better luck, as test tones and meters are proving hard work on this?
  2. scoobysti
    scoobysti
    Aug 16, 2004
    547
    28
    Derby
    +36
    if your talking about the settings on the pioneer i had alot of problems with speaker output levels, there was a problem with the firmware, just coulnt get the levels set correctly, quite a few people reported the same problem, i didnt use the settings and had it as default.
    dont know wether the latest firmware has sorted it, i use HDMI to an onkyo amp now, far easier.
