trickadero
Hi all,
Looking for some advice as I'm in analysis paralysis!
We've recently moved and I'm collecting gear to kit out the lounge, but struggling with surround speaker choice. Room is a good size and shape; basically square @ 4.9 x 4.8 metres, but a door and friendly for wife/kids means placement and speaker choice are relatively static.
I've attached a pic of the room. TV is on the chimney breast directly opposite the MLP (4 metres away). LCR will be mounted to the breast (2.5 metre separation between LR). Sofa will be back against the opposite wall, maybe a foot or so away from the wall itself (4m to TV).
Kit I've got:
LCR - Kef T301
Ceiling - Kef Ci130ER
AVR - Denon X2600
Sub - XXLS400
The surrounds will have to go on the back wall due to the double door on the left and out slightly wider than the front as there's a window to avoid. The decision I'm struggling with is whether to go with:
1, Kef T101 - match the rest of the speakers, but will have to sit flat on the wall as opposed to angled to the MLP so not ideal
2, MA Bronze FX - still wife friendly, but mixed views on whether these work well with Atmos
3, Something else which meets the criteria?
Both the same price. Bookshelves on angled brackets have been banned. If I went with the MA I'd probably swop out the Kef ceilings for MA ones, but perhaps unnecessary.
For context we're coming from a Plasma in the corner of the room with a Tannoy HTS101 5.1 system so any improvement over that and I'm golden, but obviously want the best I can with what I have to work with.
Would really welcome opinions!
Kit I've got:
LCR - Kef T301
AVR - Denon X2600
Sub - XXLS400
