4x HDMI switcher + optical, V+
Discussion in 'Cables & Switches' started by UglyChild uk, Sep 15, 2007.
  1. UglyChild uk
    UglyChild uk
    Oct 28, 2006
    325
    Southend-On-Sea
    +18
    Ok realise a bit of a random title but....
    I'm looking for a 4-1 HDMI switcher with the following requirements.
    4 HDMI inputs which will support. V+, Pioneer 696, 360 Elite & my HTPC (all in sig). Now would preferably like to have 4 way optical switching aswell and it must be compataible with my Harmony 525.
    I thought I had everything i needed in the Thor .http://www.tvcables.co.uk/cgi-bin/tvcables/thor-hdc100-4-way-hdmi-switch.html
    However I now hear that it doesnt work with V+. This would obviously throw a big spanner in the works.
    Can anyone confirm that the Thor will or wont work with V+ and if not can can someone recommend an alternate?
    Thanks in advance.
  2. obvious123
    obvious123
  3. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,746
    The Borders
    +3,516
    Hello simonhippsey
    As Mr THX says the Octava HDS4A-UK will do what you require and works with the Sources you list - including any HDMI v1.3 features your System supports.
    A more expensive option is the Zektor HDMI5 - this unit adds lots of features to the basic switching requirement; including the ability to cross covert Co-axial and Optical Digital audio; see http://www.zektor.com/hdmi5/index.html
    Joe
