4x 8x 16x dvdr's whats the diffrence apart from speed
Discussion in 'Computer Components' started by oxygenuk, Sep 8, 2005.
  1. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,650
    38
    +13
    Hi i wanna buy some dvdrs (havent burnt before dvds before).
    what id like to know is what dvdr's are best to go for, does it matter what speed i choose as far as playing back on dvds players are concerned?
    or is it just down to how fast your dvdrw drive can write? (mine can write at 16x on single layer i think)
    got the hang of the cd biz now so just need this little bit of help which makes me feel stupid asking in a way :rotfl: .
    thx in advance :)
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    I can't see any reason but speed, although as with cd-r's different manufacturers make disks that are more compatable than others. Although in my experience even cheap ones work in dvd players, i suppose it depends on how picky your player is.
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
  4. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,522
    Detached from reality
    +1,594
    The rating is the speed that the disc can be written to so x16 will be more expensive than x4. It is all down to how impatient you are :)
    I generally use x4 as my iMac burns at x2 (lol) and they are cheaper. Don't be tempted to buy unbranded discs for data or DVD. I made this mistake and 50% were corrupt. I get on well with TDK but any good make will be fine.
    Just make sure you choose a format (-R, +R etc.) that your DVD player can play. Most play -R ok so that is what I use but some older domestic DVD players won't.
  5. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    -R is usually good for write once, i.e you want to copy a dvd or game, +R is usefull for data backup/archiving...
  6. phunkey_monkeh
    phunkey_monkeh
    I find using 16x disks no quicker than 8x disks.
    Its daft.
