4s problem, keep getting "no service"
Discussion in 'iPhone Forum' started by celtic1967, Feb 20, 2014.
Tags:
  1. celtic1967
    celtic1967
    Oct 17, 2005
    1,119
    Luton
    +38
    I have an iPhone 4s, bought on here and randomly but frequently I get zero phone bars and "no service" then it will come back to say three bars and then it will repeat this a few minutes later.
    This interrupts phone and texts, but wifi is ok.
    I have swapped my sim with my daughter (also 4s) and it seems to be that my phone that is the common denominator.
    Any ideas what the problem could be ?
  2. tom 2000
    tom 2000
    Mar 21, 2008
    3,988
    Craigavon, Northern Ireland
    +407
    Welcome to my world.
  3. Blujelly
    Blujelly
    Jul 26, 2012
    99
    11
    United Kingdom
    Have you tried resetting network settings?
  4. UberCoder
    UberCoder
    Apr 10, 2014
    64
    +4
    I would try completely restoring the phone back to default and latest IOS. If it's still problem you will need to send the phone into someone for repair. It could be many things but is usually either the aerial connector not being plugged in correctly or its more likely what they refer to as the blue signal coil.
    It's easy to remove the back and check if the aerial is plugged in correctly. But as for replacing the signal coil, it takes someone skilled at soldering. The coil is cheap to buy if your comfortable at doing it yourself.
  5. Darision
    Darision
    Apr 12, 2014
    39
    11
    wales
    +5
    I had this problem with my phone, you could try taking out the simcard and wiping it down with a clean cloth and re inserting it into the phone and see if that helps, it worked for me.
