4s on vodafone 3g issue
Discussion in 'iPhone Forum' started by killer10971, Jan 8, 2012.
Tags:
  1. killer10971
    killer10971
    Dec 29, 2004
    1,101
    +35
    i have my 4s on o2 and soon as i switch off wireless or leave wireless range i pick up a 3g signal , my wife who is on vodafone if i do the same with her handset it wont pickup 3g unless i turn off/on the handset
    once i do it once its fine and i can switch between 3g and wireless ,just seem to get stuck
    any ideas
  2. bpsmith
    bpsmith
    Jan 8, 2010
    7,572
    +709
    Not sure why it does that, or a fix, but if you go into Settings and toggle Airplane Mode On and then Off it will search for a new mobile signal. Will save you turning Off and In completely to get the signal while you resolve the other issue.
  3. killer10971
    killer10971
    Dec 29, 2004
    1,101
    +35
    would having data roaming on help???
