4s battery replacement.
Discussion in 'iPhone Forum' started by sbaddison, Aug 16, 2013.
Tags:
  1. sbaddison
    sbaddison
    Oct 2, 2005
    359
    Warwickshire, UK
    +6
    Evening all.
    Who would you trust mail order wise to put me a new battery in without wiping my phone?
    Anyone on here do it?
    Anyway of telling what capacity is left on the original battery?
    Sorry for all the Q's!
    Cheers,
    Simon
  2. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,296
    +677
    Think Apple charge £55 if you take it in store. Only ones I would trust tbh.
  3. sbaddison
    sbaddison
    Oct 2, 2005
    359
    Warwickshire, UK
    +6
    They say data gets wiped :( Our broadband is so slow a backup would take a week. Ditto our home PC.
  4. Min125
    Min125
    Aug 14, 2013
    16
    3
    +3
    It's very easy. I've done many part replacements on 4. Undo the two tiny torx screw in the bottom, order a screwdriver off eBay. Cheap. Slide the back up and lift off. Remove the one(?) screw holdin battery connection in place and lift tab off. Pull clear plastic that says something about battery it's stuck with glue so a lot of pulling. Out new one in. And reverse steps.
    Have you tries a battery monitoring app and have you tried cycling it?
  5. PHOTOSHOP KID
    PHOTOSHOP KID
    Nov 13, 2005
    1,515
    +162
    Do they change batts while you wait?
  6. rjkgr
    rjkgr
    Aug 21, 2013
    165
    +6
    i did my battery for my 4s and nothing bad happened and mine barely could hold charge for 2 hours so i needed a new battery
  7. bransoj
    bransoj
    Oct 29, 2009
    2,776
    103
    +474
    Not just the issue of doing it yourself but the standard of the replacement part. Have it done by Apple and you get 90 days warranty plus i dont think they replace the battery but actually give you a refurbished phone. Not sure on that last bit though.
  8. JUS
    JUS
    Jan 21, 2003
    3,434
    Plute
    +322
    Not sure I understand. Why can't you back to your PC?
    I'd got for Apple as well. I got a third party to replace my case and now wireless doesn't work
  9. sbaddison
    sbaddison
    Oct 2, 2005
    359
    Warwickshire, UK
    +6
    Our home PC is ancient. Too slow, don't have 32gb free.
  10. chojin
    chojin
    Nov 1, 2004
    652
    Oldham
    +55
    It's a very easy process to change a battery, lots of videos on YouTube showing how. A genuine battery and tools should cost you no more than £15-20.
    But I would cycle the battery first to be sure.
  11. alextodd
    alextodd
    Sep 7, 2013
    24
    3
    Simply go to your Local Repair Shop, and tell him the problem followed by what do you expect from him, he would surely take backup of your entire phone and would return it to you just like it was before (Of course with a new battery). In my opinion, don't go for the mail order one's as if they do any kind of blunder than you would need to keep on writing to them about the issues you are having with new battery or with your data, and this thing will take a good number of weeks to get fixed.
