4mm Soldered Banana Plugs : Where to Buy?
Discussion in 'Home Cinema Building DIY' started by joust, Jul 26, 2003.
  1. joust
    joust
    Sep 4, 2002
    858
    28
    Basildon, Essex
    +49
    Hi All,
    I'm just about to start making up some FFRC speaker cables for my LR fronts (and may also have somwtime to use the workshop at work). I have followed the links in the sticky, but they don't seem to work anymore. Can anybody point me to a good website to buy 4 pairs of solderable banana plugs (if they sell good quality solder that would be good also)?
    Joust
  2. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    menalaus ones are the best 4mm plug I have used. Worth every penny. Large contact area
    Gordon
  4. joust
    joust
    Sep 4, 2002
    858
    28
    Basildon, Essex
    +49
    Hi Gordon,
    Are these solderable and where can I find them?
    Joust
  5. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    MENALAUS is the name of the first respondant to you rquery. He posted a link to the ones that I recommend from CPC in Preston. They are crimp and solder types. They are cheap and great.
    They also fit BFA style connections on some UK amplifiers as well as 4mm sockets
    Gordon
  6. potfish
    potfish
    Apr 8, 2003
    380
    Bristol
    +5
    That link doesn't work. Could you give more details on these parts so I can try to find them by browsing, or alternatively post a new link?
    potfish
  7. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    It worked for me when it was posted. Now it doesn't...
    CPC Product code
    red CN01999
    black CN03001
    4mm stackable test plugs holllow
    Gordon
  8. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
  9. potfish
    potfish
    Apr 8, 2003
    380
    Bristol
    +5
    Cheers guys
  10. Tracey
    Tracey
    Hi Gordon are these easy to fit? I need some new banana plugs as mine have come loose and I want to bi-wire and bi-amp. Do I need a special crimping tool and a special type of solder. Will any soldering iron do the job?
    Tracey
  11. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    No special crimp tool. Just some pliers. 60/40 solder and a decent iron.
    Gordon
  12. Tracey
    Tracey
    Thanks Gordon, I've never soldered anything before but I know a man who has!
  13. beaverme
    beaverme
    Dec 9, 2008
    1,760
    48
    Manchester
    +44
    If I wanted to use a crimping tool on these plugs, for consistency, which tool would I need to buy?
  14. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    2003...im suprised im still alive
  15. beaverme
    beaverme
    Dec 9, 2008
    1,760
    48
    Manchester
    +44
    Congratulations on making it to 2009! I realise it's an old thread but I've been trawling the Internet for ages looking for advice on how best to crimp these plugs, without much success.
