4KUS DVR-230 DVD recorder multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by AcerKev, Mar 20, 2005.
  1. AcerKev
    AcerKev
    Mar 30, 2003
    95
    Nottingham, East Midlands (UK)
    +3
    4KUS DVR-230
    (DVD+RW Recorder on sale at Asda)
    Press [SETUP]
    Highlight "Exit"
    Press [2960]
    Press [>] then [>]
    Highlight the regioncode you want
    • Region Free
    • Region 1
    • Region 2
    • Region 3
    • Region 4
    • Region 5
    • Region 6
    Press [Enter]
    Press [<][<][<]
    Region Free works fine for Region 2, Region 4 and Region 2+4 DVDs
  2. CBers
    CBers
    Apr 6, 2006
    325
    +49
    How do you highlight EXIT ??
    The only way to EXIT is via either the RETURN key or the HOME MENU key.
  3. AcerKev
    AcerKev
    Mar 30, 2003
    95
    +3
    When you press "setup" on the remote control a list of setup options is included, on my model these are System; Language; Playback; Record; Audio; TV Tuner; and Exit, you use the cursor keys to highlight the Exit option.
    There is neither a RETURN or HOME MENU key on my remote control though.
  4. f90x
    f90x
    Jun 7, 2006
    5
    Hi, a newbie here.
    I have just bought one of these with this hack in mind. however when I get it set up I find that my remote 'VXX2982' does not have a 'setup' button, just the 'HOME/MENU' button that takes me to the 'disc navigator, editing, timer recording, initial setup and 'play mode'.
    What happens next? I have subsequently searched all over the place and I now find that I need a disc in order to make my machine multi region. can anyone shed any light on this problem for me.
    Steve
  5. AcerKev
    AcerKev
    Mar 30, 2003
    95
    +3
    Can't help you i'm afraid, but it sounds like the DVR-230 and the DVR-230S are running totally different firmware and have different r/cs
  6. f90x
    f90x
    Jun 7, 2006
    5
    That's a bummer. Thanks all the same
