4kus dvr-230 (Asda)
Discussion in 'Blu-ray & DVD Players & Recorders' started by PhilDick, Apr 26, 2005.
  1. PhilDick
    PhilDick
    Hi all,
    I have just bought a 4kus dvr-230 from Asda (now £120) and have noticed a strange problem with it. The RGB doesn't seem to switch properly. If you switch the machine on and it is on the AV (SCART) channel you get an RGB signal which you can record from no problem. But if you play your recording then switch back to the AV channel you get a composite picture. The machine then records in composite until you switch it off and on again.
    My set up is a Telewest cable box with RGB SCART out to the in socket on the DVD and SCART out to the TV.
    Has anybody else noticed this or is it a fault with my particular machine?
    Phil
