4k tv under 1200€
Blackbanana
So it's time to replace the old 42" HDready tv. I've been looking around a bit but its pretty much to keep in mind when buying a new tv so i thought i would turn to you guys.
Budget:
1200€
Seating distance:
10 feet.
Size/placement limitations:
No smaller than 50". 50-60" is ideal.
Uses and sources:
The tv is going to be mainly used for movies and gaming. The source of movies i'm gonna use whatever is available i guess Piratebay, netflix etc..
For gaming/movies im gonna use a HTPC. The movies will be watched in 4k. But the games in 1080p-4k. Whatever the GTX 970 is going to be able to handle.
I'm gonna be using a amplifier and speakers so the tvs inbuilt speakers isnt a problem.
HTPC:
Motherboard : m5a97 r2.0
CPU: AMD FX-6200 Six-core 3.8Ghz
GPU: (GTX 970 Hdmi 2.0)
Ram: 8Gb ddr3 1666Mhz
Thanks in advance guys!
