4K Passthru
Discussion in 'AV Receivers & Amplifiers' started by grannygear, Dec 20, 2016.
  1. grannygear
    grannygear
    Dec 12, 2016
    4
    Halifax, NS
    I have a receiver with 4 K passthru, but not HDCP 2.2 support. The outputs are labelled 4K. When I stream 4K content from a ROKY, it is displayed in 1080P on my 4K TV. So, is there any practical use for the 4K passthru?
  2. dante01
    dante01
    Mar 5, 2009
    45,831
    +10,948
    Without HDCP 2.2 compliance then you are unlikely to be able to handle or passthrough natively encoded UHD content because almost all such content uses HDCP 2.2 for copyright protection and DRM purposes. The best you can hope to passthrough is HD or SD content scaled up to 4K prior to the receiver or 4K content you've created that isn't protected by HDCP 2.2.
  3. grannygear
    grannygear
    Dec 12, 2016
    4
    Halifax, NS
    Thanks for the reply. One thing I don't understand is why a Roku Premiere, outputting 4K, run thru my receiver, displays 1080P on the TV. I would have guessed I would have received an HDCP 2.2 error. Make sense?
    When I run the same Roku and content to a TV HDMI port, it displays in 4k and I get audio on ARC...
  4. dante01
    dante01
    Mar 5, 2009
    45,831
    +10,948
    It depends upon what you are using to source the content. THe Roku is simply a device on which other services or apps run. Those services carry content that may or may not be protected by HDCP 2.2 depending on whether it is or isn't UHD in nature. THe RoKu simply employs an HDCP 2.2 compliant HDMI output and doesn't encode everything it outputs with HDCP 2.2 copyright protection. You only need HDCP 2.2 compliance when dealing with UHD content.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,599
    The Borders
    +3,494
    You could use an HDFury Linker to 'fool' the ROKU into seeing an HDCP 2.2 enabled Sync.
    Joe
  6. grannygear
    grannygear
    Dec 12, 2016
    4
    Halifax, NS
    The thought had crossed my mind....
