Question 4K over 15 meters - HDMI, Fibre, Ethernet = one confused consumer
Joe Fernand
AVForums Sponsor
ARC with the longer cables (15+) can be very system dependent so tricky to predict without running an actual test.
RuiPro4K - as per the original ‘Henry Ford’ it is black or black, if required you could easily put the cable in a white mesh sheath at minimal cost.
Joe
groovyclam
OK, I've not read the whole thread and I know diddly-squat about projectors, so don't kill me if I'm talking crud...
I've recently set up a 30m stretch of HDMI from one end of the house where the PC(Home Theatre) is to the 4K TV in the lounge. The HDMI cable snakes through the fabric of the building and even goes under the garden deck outside.
I used Lindy products ( bit expensive but they let you return them if the setup doesn't work ).
I used 3 x 10m 4K capable HDMI leads, joined together with 2 x HDMI repeaters:
cable link -- 10m Premium Standard HDMI Cable - from LINDY UK
repeater link -- 40m HDMI 2.0 18G Repeater Premium - from LINDY UK
Now, my current source is NOT 4K ( working up to that ) but a 1080p ( with sound ) from the PC is rock solid on the TV.
I wondered if the repeaters would need a power supply ( that is an optional extra ) but it has turned out not to be the case. I would think if the 4K supply fails over this setup when I get a new 4K HomeTheatre, then adding a power supply to one ( or both ) of the the repeaters would fix this.
If 15m is your required length then you'd only need one repeater between 2 x 7.5m HDMI leads.
link -- 7.5m Premium Standard HDMI Cable - from LINDY UK
The repeater is about the size of a box of Swan matches but the Lindy cable is very chunky.
With VAT and postage it looks like it would cost about £150 total.
Possibly relevant addendum: if you need to get an IR remote control signal back along the HDMI cable to control the projector, then I use this successfully with the above setup:
ChuckMountain
So in summary you have got what you know as a working solution for 1080p but spent more money than a solution that we know works for 4k at the same distance ....:confused:
D
Deleted member 24354
@ChuckMountain you beat me to it, i was about to post almost the same response.
@groovyclam I really would suggest reading entire threads. Many of the people here are industry experts offering technical advice based on commercial experience, your solution, though well meaning is a bit of a Frankenstein and is unlikely to meet the OPs requirements. It maybe an adequate solution for you currently but is not something that I would use or recommend to a client.
You may also want to look at Lindy's small print, those repeaters are only tested with Lindys' Gold cables which for an equivalent length to the Premium Standard which you linked, are double the price
And neither cable are Premium Certified. Whereas a premium certified cable on amazon, would cost you £19.99
groovyclam
Well, I thought it might be useful to post an actual case study that works in reality.
I did start to read the entire thread but then the tech-heads started throwing blah around and I lost interest.
It is just as valid to hear an opinion from someone who has done something that works, than theoreticals.
The original poster can make their own decision based on my post and costings - he can ignore my post or not.
As to your snark ChuckMountain, my requirement was for 30m ( not the posters 15m ) so my costings are not excessive - unless you want to tell me how I get 4K along 30m of HDMI for less than what I paid ?
@mushii - I'll take the point about Amazon cables being cheaper ( but the Lindy cables are Premium - it's in the tech specs )
I still don't see what's wrong with the original poster using two of those Amazon slimHDMI cables at 7.5 metres with the Lindy HDMI booster in the middle for belt and braces.
Otto Pylot
There is a definite, continuing learning curve with a/v so don't feel bad about asking a question. That's how we learn.
The simple plan that I use, and then adjust as necessary, is as follows, and this is for 4k HDR:
For runs up to 25' (8m), Premium High Speed HDMI cables (with the QR label for authenticity) should work.
For runs over 25' (8m), and up to 30m, a hybrid fiber cable (Ruipro4k) is probably your best bet. These cables are active (require a power source which is usually drawn from the sink side).
That being said, the best and most reliable connection is a single cable from source to sink with no adpaters, extenders, wall plates, etc in-between because 4k HDR can be very finicky with its connections. Most mfrs of active cables (copper-only, fiber, and hybrid fiber) do not recommend daisy chaining your cables together. Heavy gauge wire should also be avoided because because bend radius is greatly reduced which can lead to increased strain on the HDMI input.
If I read your connection scheme correctly, your cable run is close to, if not a bit over 30m. That is long for any cable so you have that working against you. Using a single cable, source to sink, is even more critical in that scenario. You should also be running your cable in a conduit so you can control bend radius (which if too sharp of a bend can drastically affect signal transmission over time) and allow for easier and safer installation of the cable, along with a pull string.
ARC/eARC will also be an issue at 30m if that is something you want to do. Unfortunately, given your situation and needs, there probably isn't a cost-effective way to do this.
Joe Fernand
AVForums Sponsor
Lindy are playing games with the wording on the 10m cables you link to - no cable over 8m is certified as 'High Speed' or 'Premium High Speed'. Lindy have added 'Premium' to Standard to create its own category of cable (they do say in the tech specs that it is a Standard cable with Ethernet).
Great you have a working solution at 1080p though as others have said that is no indication of how teh system will work with 4K UHD source signals.
Joe
groovyclam
Aha, good to know ( or not so good in my case ).
Otto Pylot
Joe is correct. Consumers have to be very careful in purchasing cables because the cable mfrs are very good, and very careful, on how they market their cables. You almost have to read between the lines of the product descriptions to see exactly what it is you're purchasing. Most consumers don't. They just latch on to the buzz words and don't go any further than that. There is a very respectable cable mfr who is now seeing knock-offs of their product that look almost exactly like their cable when it comes to product description, packaging, and marketing for about half the price. However, the build quality is not there.
D
@groovyclam please lets not degenerate into name calling. If you are unhappy with somebody's response its fair to say so, but to start being base and using profanity benefits noone. Everyone is entitled to an opinion and to disagree with somebody elses, but there are people here with tens of years of experience in this industry, who give their time up, gratis to help other forum members. To ignore their input and then to say that you couldnt be bothered to read what they have said is also kind of hurtful and really, you then denigrate years of technical knowledge as 'blah' is just plain rude.
Lindy cables are not 'certified' as premium high speed. You also need to read their wording very carefully as they are 'flexible' with their facts and imply things by using weasel words. I have used their products in the past but lets just say that the 'sizzle' was better than the sausage.
Below is the 'L' section from the hdmi.org database (the organisation that certified the cables)
You will note that Lindy are not present and neither do their cables bare the QR Hologram of certification. Maybe a little more 'blah' for you to ignore.
ChuckMountain
So my original reply was quite short because I was on my phone...
You haven't however got a working 4K solution, only a 1080P solution. If the OP wanted 15m at 1080P then he could have just one direct copper cable.
I genuinely hope your solution works when you do upgrade but I suspect a combination of the 10m cables and repeaters will give you a number of issues, which will result in you having to shell more money and time out to resolve.
Unfortunately, you have not got a working 4K solution only a 1080p solution. If you are going to post on a technical forum post then make sure your solution does what it says on the tin. Yours is the only theoretical solution currently.
I see you edited your post a bit but here you go:
30m @£169.99
15m @£139.99
These work :)
As per others' posts, no they are not.
Apart from the fact you don't know whether it works at 4K, it is still best to have a single run. It is matchbox size, it still steals power and you have to put it somewhere, it does not fit neatly into trunking, skirting etc so it is more difficult to install and more to go wrong.
One of the best solutions has already been suggested, but you seem to have taken offence when somebody points out that your solution does not meet the OP's requirements and can be done for a similar cost.
Learn some forum etiquette, read the posts, if it is too technical and you post something don't be afraid to let people critique it!
gibbsy
@groovyclam Can we keep answer civil please. I've have deleted one of your replies.
Otto Pylot
Wow. I'm almost sorry I contributed to this thread. If I may summarize, for 1080 just about any well made cable will work, even at 30m. But at that length, either an active cable or a passive cable with possibly a voltage inserter would be more reliable. The other caveats about wire gauge, bend radius, conduit, and strain on the HDMI input still hold true. A hybrid fiber cable (Ruipro4k would also work, although it may be a bit of an overkill for just 1080). For 4k HDR, I'd recommend a 30m Ruipro4k cable installed in a conduit. Source to sink. Period.
groovyclam
I think ChuckMountain's reply to my original post was quite uncivil but no-one jumped on him.
His second post above is a far better reply without snark, perhaps that's how he should have replied first.
I come from a computer programming workplace and there is a considerable level of one-upmanship and snark in that community. It comes from a desire to "guard" knowledge and thus feel more important about oneself.
Posters like @Joe Fernand and @Otto Pylott show a far more civil and educational way of replying to posts that they feel need critiquing and I applaud them for that. I would say to other posters... follow their example.
groovyclam
I made my post quite clearly stating it wasn't sending 4K HDR yet, and the original poster can make of that what he wants. Or should I have not posted at all then ?
I took offence at the nature of your glib post, not the message, daft emoji included. If you had just said "a better solution is x,y,z for reasons a,b,c as mentioned 3 posts up" then I would not have been offended. You were just being obnoxious to a noob for cool points. If this forum is not for noobs then eventually it will die when the gronards die out. So I say to you as well in your own words... learn some etiquette.
And moderator... "if learn some etiquette" is going to get this post deleted then delete Chuck's too.
ChuckMountain
took offence at the nature of your glib post, not the message, daft emoji included. If you had just said "a better solution is x,y,z as mentioned 3 posts up" then I would not have been offended. You were just being obnoxious to a noob for cool points. If this forum is not for noobs then eventually it will die when the gronards die out. So I say to you as well in your own words... learn some etiquette.
What's bad etiquette is not bothering to read the previous posts, then posting something that doesn't meet the original OP request. Other posts agree with my original post. Then you ask somebody to point out the particular post answers the question in the thread that you didn't read. As for the smiley, it is the commonly used one on the forums for confused as your response is confusing. It still doesn't meet the requirements for the OP something cheap.
I am simply stating a fact, you resort to insults that's why the post was deleted.
D
I will agree that Otto and Joe are far more tolerant and have a different communication style, of that you are correct - and I applaud them for their cool headedness. I on the other hand am not quite so diplomatic. I do apologise to the OP for hijacking his thread, you did not deserve this and hopefully you have the answer to your original question. other than that I have nothing more to add to this thread.
gibbsy
This thread has taken a turn for the worse and is now getting very close to be locked.
mooperman
Not sure if useful to the OP with everything going on but - i bought this cable the other week and am having no problems with dolby vision/atmos/HDR using an Apple TV 4k and a Panasonic UB820 UHD player - i am having some problems with a 1080p sky box but im almost certain thats related to the HDMI switch im using...
ChuckMountain
It's good to know that some of the cheaper cables are working well now especially since they are hybrid cables. I know early adaptors often charge more to cover the research costs but given HDMI 2.1 we are more likely to see these over shorter lengths.
What issues are you having with sky and is it sky HD or q?
mooperman
its an older sky hd box - looking at the switch i have it says "compatible with hdmi 2.0 devices" so im guessing my old sky box is probably a 1.4 at best... ive had it for donkeys - might call them with a cancel my tv sub unless i can get a new box and if i cant im happy to cancel anyways. :)
ChuckMountain
HDMI versions are backward compatible so the switch should work with older versions. However as the sky HD box is quite old it could have some of its own issues which don't help.
Switches also can be problematic as HDMI can be fickle and some devices can take longer to switch. :(
You could always upgrade to Sky Q to get 4k, probably means giving sky more money though :censored:
mooperman
yeah it does open up ok with sound/video but after a few minutes starts flickering and then gone entirely whereas all my 4k sources hold with zero problems - def a weird one!
i'll change the cable before doing anything else but it was working ok prior to the switch being installed.
Latest News
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
PSB announces M4U 8 MKII wireless headphone
  • By Andy Bassett
  • Published
Melco introduces N50-S38 music library
  • By Andy Bassett
  • Published
Sony expands 360 Reality Audio to Amazon Music Unlimited
  • By Andy Bassett
  • Published
Google launches Pixel 6 and 6 Pro smartphones
  • By Andy Bassett
  • Published
