4k let down
Discussion in 'General TV Discussions Forum' started by scott61985, Jan 10, 2019.
  1. scott61985
    scott61985
    Jan 9, 2009
    154
    19
    Is it just me or is anybody else diserpointed with 4k. Upgraded my old sony 2013 model with a new lg 4k led. Set it up using the AV forums picture perfect and still Let down with it. Doesn't look like it did in the shop even. 4k content is poor Amazon prime 4k doesn't look much than 1080p. Not bought any 4k bluerays yet not cheap at all.
  2. Sonic67
    Sonic67
    Sep 14, 2006
    43,265
    11
    167
    Home
    +21,293
    How good is your eyesight?
    How close do you sit to it?
    How big is your 4K set?
    How much did you pay for your new set?
    If you had a good previous set then you won't be so impressed as if your previous set was a small, HD Ready supermarket special.
    What are you watching on it?
    What about HDR or Dolby Video?
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,875
    2
    In a secret location with Jennifer Lawrence
    +10,929
    Not looking like it did in the shop is a very good thing. Tvs look hideous in shops.
    My 2017 LG OLED is a superb tv and everything looks great on it. What 4k programmes have you tried on Amazon?
  4. EpsilonVaz
    EpsilonVaz
    Mar 12, 2009
    175
    Surrey
    +22
    Having gone from a Kuro and VT65 to an LG C8, yes, 4k is fantastic. I am still blown away by detail in scenes. HDR takes it to an entirely different level.
    Which TV do you have? What is your internet connection speed?
  5. ckyliu
    ckyliu
    Nov 21, 2018
    33
    UK
    +5
    If you're not on fibre you will not get a 4K stream. My Netflix downgrades to 1080p because my 10 Mbps broadband can't keep up.
  6. scott61985
    scott61985
    Jan 9, 2009
    154
    19
    Hi sorry for late reply the TV is a lg 65uk6950plb. My internet is virgin fiber vivid 200 TV and Xbox all using ethernet wired. I don't know if I was just use to how my old TV was I never set it up just used it out if the box. And this time used the picture perfect of here can't seem to get the whites from looking yellow and always looks dim.
    I've watching the grand tour and Jack Ryan
    I payed £800 for it lg65uk6950plb
  7. furryhobnob
    furryhobnob
    Jan 15, 2010
    14,395
    Hugglescote
    +7,178
    Whites on a correctly setup tv should look like a piece of paper being held up to the sun, they are yellow in tone, this is correct and probably because you're used to how your old TV was setup straight out of the box in vivid mode no doubt where the whites would have had too much blue in them to make them look whiter, it just takes some getting used to watching a more visually correct image if you're used to an incorrect image
  8. scott61985
    scott61985
    Jan 9, 2009
    154
    19
    Yhanjs
  9. Curt101
    Curt101
    Jun 4, 2018
    S. Florida, US
    +31
    You do realize that there is a separate entry for the 4K versions of these on Amazon Prime. If you just play the first one you come to it is in 1K. You must see the UHD in the thumbnail and the HDR/DV icon in the description. Amazon hides the 4k versions, scroll way way down on the home menu.
  10. ckyliu
    ckyliu
    Nov 21, 2018
    33
    UK
    +5
    I think you mean it's in 2K/1080p as standard. 1K would be under 720p!
    The K's measure horizontal pixels, the i's and p's measure vertical resolution. 4k is 2160p.
