Question 4K Blu-Ray Player vs X Box One S
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dead5tar, Jun 26, 2019.
    1. Dead5tar
      Dead5tar
      Oct 5, 2010
      142
      Witney
      +18
      Given that there have been updates to the Xbox re audio formats etc, are they still considered a poor substitute for a 4K Blu-Ray Player, a DP-UB450 for instance?
    2. Waynej
      Waynej
      Oct 4, 2004
      8,405
      Wales
      +1,447
      There used to be issues in the past with the colours but I recall reading that this was fixed.
      I went for the Panasonic UB420 a few months ago. It ticked a few boxes vs. the Xbox that to me made it a worth while purchase.
      Disc reading is far quieter.
      HDR Optimiser highly appealing over any other player.
      HDR10+ support unlike the Xbox (my TV does HDR10+ not DV)
      Cheap refurb (£79.99) from Panasonic Outlet ebay with 1-yr warranty. Additional perk of not needing to toggle game mode off/on for the Xbox any more.
    3. Dead5tar
      Dead5tar
      Oct 5, 2010
      142
      Witney
      +18
      Quiet disc reading is an important one for me... our PS3(i know.. it's old :blush:) is almost audible over the vacuum cleaner:D
    4. aenimiac
      aenimiac
      Mar 3, 2010
      +33
      I don't believe the Xbox One supports Dolby Vision on discs so if that's important to you then you'll have to get a standalone player.
    5. dante01
      dante01
      Mar 5, 2009
      46,865
      +11,314
      The XBox is considerably noisier than a standalone UHD disc player and will generate more heat than a dedicated player. The XBox is also limited to just one HDMI output which makes it less flexible when it comes to using one in conjunction with oder AV receivers. Having 2 outputs facilitates conveying UHD HDCP 2.2 protected video directly to a compliant dilay while simultaneously conveying HD audio to an older non compliant AV receiver via the second HDMI output. Most standalone UHD disc players come equipped with 2 HDMI outputs.
    6. Doctor Smith
      Doctor Smith
      Apr 3, 2007
      2,524
      Loughborough
      +291
      I have had both. I compared a Panasonic ub700 with the xbox one s and the xbox displayed banding in certain scenes where the panny didn't. Also the noise of the xbox was very distracting if you are viewing a dialogue heavy movie.
    7. L4_Isoside
      L4_Isoside
      Feb 12, 2007
      593
      +83
      I have an Xbox One S and a Sony ubx700 and from audio and picture perspective I couldnt tell a difference.
      I wanted a standalone player that did Netflix and films and then a games console. However, because Netflix can't do Atmos (which I only found out after I purchased it) on the Sony I now use it as a disc player only.
      I don't like how the Xbox wraps up everything under Atmos even if the content is not Atmos (doesn't apply to disc's though).
      If i had to choose one (as i did originally) id choose the Xbox as its more multi functional.
    8. Dead5tar
      Dead5tar
      Oct 5, 2010
      142
      Witney
      +18
      Thanks for the replies chaps... helped me make my mind up .... I've gone for the DP-UB450:thumbsup:
