4Gb Zen prob.
Discussion in 'Headphones, Earphones & Portable Music' started by sbowler, Jan 13, 2008.
  1. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    Fixed it.:thumbsup::thumbsup::thumbsup: theres the tiniest reset button in the world on the bottom edge. up and running.
  3. Crookloq
    Crookloq
    Sep 30, 2007
    26
    3
    A-ha, i'm having the same problem with the wifes player, the reset doesn't seem to be doing much apart from turning the unit off.
    Anyone with any help would be much appreciated:smashin:
  4. den9112
    den9112
    Feb 8, 2004
    2,188
    83
    +365
    Just had the same problem , flickering screen with a white line across . Eventually got it to boot up . Got it up and running this morning for about a hour , switched off then back on again and no response from the player .Had to return to store and they could not get it to work . Came home with a ipod nano 8gb .
