Goofy1314
Hi folks, i'm currently in the market for a new TV and this seems like the best website for info/help.
I'm UK based so obviously looking for something that is readily available over here.
I've recently pre-ordered the new Xbox One X which is due out in november and i want a tv that's going to make the most of the 4K/HDR abilities. Ideally looking for a 49" or 50" due to size constraints and distance, 55" at a push.
I generally play in a darkened room and the tv will also be used for watching movies (mainly action/horror type stuff) and sports. I also have Amazon prime so will no doubt take advantage of the 4K content available on there too.
So, sources will generally be full HD through SkyHD, Xbox gaming and more than likely 4K streaming.
Budget....... at a push i could probably stretch to £800
So far, the one i'm leaning towards is this - Buy LG 49SJ800V LED HDR Super UHD 4K Ultra HD Smart TV, 49" with Freeview Play, Ultra Slim Design & Harman / Kardon Soundbar Stand, Silver | John Lewis
Thanks for any help/advice, if any further info is needed in order to assist making a good choice then please feel free to ask.
Cheers, Goof.
Cheers, Goof.
