mrback
Hello to all.
I currently have a samsung lcd panel & am using the madcatz component cable.
In the wii settings I have tried 480i & 480p across the component cable.
In all honesty I can't see a big difference at all between the two settings, zelda is a bit more garish on the 480i setting but 480p isnt a big difference.
Is this how it should be or should there be a pretty big difference between the two settings? I'm sure I read in another thread that there is double the pixels on 480p compared to 480i.
Hope someone can help.
Thanks in advance
Thanks in advance
