4805 resolutions via VGA
Discussion in 'Projectors, Screens & Video Processors' started by mavice, Aug 27, 2005.
  1. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    Can anyone tell me the max resolution from PC to 4805 via the M1 to VGA cable :lease:
    PC VGA output - I would like nativ 848 x 480 - is this possible or only via DVI - which my laptop does not have. :rolleyes:
    also - is refresh freq improtant for PQ ? 60HZ 72Hz ?? Higher , Higher... :smashin:
  2. mjn
    mjn
    May 24, 2001
    22,270
    Herts, England
    +10,130
    Whats a 4805?
  3. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    sorry
    - thought the Infocus Screenplay 4805 DLP front Projector (in silver)was so infamous that I could abreviate it to 4805. :D
    has anyone driving from a HTPC used vga at native res ?? :lease:
  4. Pulsar
    Pulsar
    Jan 19, 2003
    3,138
    West Midlands - Stourbridge
    +332
    mavice,
    You can get 848 x 480 resolution from a VGA socket using a computer application called Powerstrip. Once you have installed the software and restarted the laptop you can create a custom resolution of 848 x 480 and even specify the refresh rate. Once you have restarted the laptop, you can use powerstrip to select the new resolution.
    With regard to which refresh rate is best, this is something you will have to play with. Generally you will find either 50hz or 75hz best for PAL material and either 59.940hz or 47.xxxhz or 71.xxxhz for NTSC (sorry for the xxx but I can't remember the decimals off hand). The best refresh rate for you will be a combination of the smoothest pans in a film, combined with the least screen flicker and any quirks of your equipment.
    Good luck, and please ask if we can help you with anything else.
    Rob
    P.S I have used my HTPC to output both 848 x 480 and 856 x 480. :)
  5. Rambles
    Rambles
    Jul 14, 2004
    8,498
    UK
    +1,358
    Also, if you are using an nvidia graphics card you won't need powerstrip as you can set custom reolutions and refresh rates within the driver settings.
  6. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    thanks for your answers :smashin: I need to be a bit clearer:-
    I am using Nvidia driver and have tried setting custom resolutons but the PJ only seems to accept 640 x 480 - when I select the native resolution the PJ reports 640 x 480 and the text is blurred.
    THe question is, really, does the 4805 take 1:1 mapping via the VGA to M1 adapter (from PC VGA output) or only via a DVI link to the M1 connector ??
    Any one with an SP4805 who has achieved this ? :lease:
    edit: Pulsar - you say you have achieved this. Was that on an SP4805 ? If so are there any setting on the PJ I need to turn on or off ?...cheers
  7. Kramer
    Kramer
    Moved to LCD/DLP PJ forum & deleted your duplicate thread there.
    :smoke:
  8. shaolin95
    shaolin95
    It will only map 1:1 thru DVI for a perfect 854x480.
  9. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    Thanks Shaolin
    suspected that :(
    so...can I get a VGA to DVI converter :rolleyes:
  10. pompeyjohn
    pompeyjohn
    Apr 9, 2007
    19
    hi there - I have the same issue.... only a vga output and the same pj
    did you get an answer to this?
  11. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    Are you sure he will remember after 2+ years?
