4805 is it Hi Def
Discussion in 'Projectors, Screens & Video Processors' started by maverick177uk, May 13, 2005.
  1. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,739
    103
    +453
    I've got a 4805 which is connected via my Denon 3805 by component, will this be good enough to display Hi Def pictures when they come out? I put all my wires in the walls but I didn't put a DVI cable in and otherwise I'll have to run a cable round the room which will look bad :nono:
    Cheers Rob
  2. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    It'll take a Hi-def input but it will down scale it to it's native 480p rather than the Hi-def 720p.
  3. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,739
    103
    +453
    So will it look any good or do i need to use a different cable?
  4. matblack
    matblack
    Jul 30, 2003
    404
    +10
    Different cable won't help, the panel can only output as many pixels as is has and it has 480
    The scaling in the 4805 is supposed to be very good so you'll get a nice picture but it WILL be 480
    MB
  5. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    the ae700 and z3 have hidef panels 1280x720, thats the minimum spec for hidef.
  6. binbag
    binbag
    Jun 16, 2004
    1,694
    +81
    It'll look better than what you're seeing now as the source quality will be higher than what most of us are watching at the moment. The 'official' 4805 thread at www.avsforum.com raves about the picture with HD sources and there are a few screenshots. Resolution isn't everything either, my 4805 was a factory replacement for the XGA LP350 and although it has a lower resolution, it produces a much more watchable picture. That said, true hi-def on a quality display is stunning.
  7. Prayer
    Prayer
    May 12, 2005
    10
    Tallinn
    I have been offered new Infocus ScreenPlay 4805 for 265£, 5700 for 660£ and 7210 for 1540£. I have two questions:
    I would be happy with 4805 in my small urban apartment, but the offered set is missing a remote control. Are there any functions that I can't access without the remote?
    And the second thing is about the M1-DA connector, I saw Dell offering M1-DA to D-Sub 15-pin (VGA) adapter cable, InFocus is selling only M1-DA to DVI adapter cable with USB. Will the Dell or any other VGA adapter cable work with 4805?
  8. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    Sorry but i don't believe those price ......where from???
  9. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    maybe he is converting the prices from a country where the retailers and manufacturers dont screw their consumers? :suicide:
  10. Maff et1
    Maff et1
    I refuse to believe such a country exists, and for a small one time fee I can prove it...
  11. Prayer
    Prayer
    May 12, 2005
    10
    Tallinn
    There was only one of each of the named PJ-s on offer on a forum.
    Everybody was suspicious because of the prices, but warranty was offered and the PJ-s were new allegedly.
    These nice things happen in Estonia only :hiya:
    I'm sorry that I have upset you, shouldn't have brought up the exact prices.
  12. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    are projectors cheap in estonia anyway? might pop over for a holiday and give your country my money instead of the rip-off britain retailers/manufacturers
  13. Prayer
    Prayer
    May 12, 2005
    10
    Tallinn
    I don't think so, but you can take a look at the prices here for example:
    http://www.aate.ee/Projektorid/
    1£ = 22,76 Estonian Crowns
