4805 and 575, progressive or interlaced?
Discussion in 'Projectors, Screens & Video Processors' started by p5yco, Aug 6, 2005.
  1. p5yco
    p5yco
    May 14, 2005
    220
    norwich
    i know this has probably been asked before, but i was hoping to find a clear answer if i start a new thread on the topic. here goes, i have just bought an infocus 4805 and a pioneer dv575. i am impressed with them straight out of the box, however im sure with some tweaking they could look even better! the main thing i am confused about is that i have it connected via component and currently have the dvd player set to progressive. reading through some articles they say that it should be set to interlaced to let the faroudja take care of that, is this correct? also, you people with the same setup, i would be grateful if you could post some of your settings and any changes you have had to make, thanks.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    As ever, see which one looks better and stick to that. I've tried prog scan turned on and off on the 575 and I couldn't see any difference hence the TX's prog scan capabilities must be similar...PJ :)
  3. Maff et1
    Maff et1
    Whereas on my ET1 the 575's prog scan mode looks noticeably (to me anyway) sharper and more stable. As PJ says, use which you prefer, it was your money, so it's your choice. But give each option a try (not just 30 seconds), what looks good initially may turn out to be a little in your face over the length of a film.
