47ET5B or something else - £850 max
Discussion in 'What Is The Best TV For You?' started by gordy01, Feb 27, 2013.
  1. gordy01
    gordy01
    Feb 13, 2007
    121
    Jersey, CI
    +9
    Hick bit of advice if anyone is able....
    I had been looking at the Samsung PS51E6500 plasma for a long time but they now seem as rare hens teeth so having to rethink :-/
    The second option was always the Panasonic TXL47ET5B LED but just before I order from JL wanted to see if there's nothing else I should consider?
    Needs:
    46" or larger (no more than 55")
    £850 max (pref from JL for warranty and ease of delivery to Jersey)
    Occasionally SD broadcasts
    Some HD (F1 and blu-ray)
    Mix of SD & HD movie viewing
    Xbox360 (but not that often)
    Room is quite light - TV next to east facing French doors, though possibly moving in 6-8 months
    Not fussed if active or passive 3D as can see benefits of both (not had headache issues)
    Any help or suggestions appreciated!
  2. gordy01
    gordy01
    Feb 13, 2007
    121
    Jersey, CI
    +9
    Now looking like a straight out fight between the 47ET5B at £725 versus the 50GT50B at £830...opinions anyone? Both seem to have a few complaints but both generally good sets!?!
    ps - costs based on JL with VAT off and local tax at 5% on (in Jersey, Channel Islands).... pricematch for the GT in at present :)
  3. Lin3ar
    Lin3ar
    Nov 26, 2005
    6,853
    +2,771
    For me it is no contest. Not only is the GT50 bigger but it is also the far better panel.
  4. gordy01
    gordy01
    Feb 13, 2007
    121
    Jersey, CI
    +9
    Thanks - P50GT50 ordered and can't wait for it to arrive sometime next week hopefully! Has ended up costing £787 all things considered which I think is fantastic :-D
  5. ballboy
    ballboy
    Oct 8, 2008
    20
    3
    +3
    Where did you find it at that price?
  6. gordy01
    gordy01
    Feb 13, 2007
    121
    Jersey, CI
    +9
    JL at £999.95....price matched to £899...then as I'm in Jersey (Channel Islands) they take off VAT (20%) and add local tax (5%), so coming out a good bit cheaper - plus still get free delivery :-D
  7. ballboy
    ballboy
    Oct 8, 2008
    20
    3
    +3
    Where did you manage to find it at £899?
  8. gordy01
    gordy01
    Feb 13, 2007
    121
    Jersey, CI
    +9
    TPS....but with JL price matching I think it's your luck if they match or not...
