47% signal strength
Harry84
Established Member
Hey guys just set up my ps3 wireless, and its reporting 47% signal strength, am i likely to get lag, or will this suffice? Or would you recommend setting it up wired?
Thanks for any replys
Harry84
Established Member
Well due to the huge number of replies ;), i've decided to just hook it up using wired as it's bound to be the better option, just gotta whip the drill out and start attacking the skirting board :D
bubs999
With that signal strength it will probably disconnect regularly. When mine used to drop to 65% it would kick me out of games. It now runs at 100% after I changed the channel. You could try that on your router? the PS3 will pick it up automatically.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
