46 Tosh RP - Digital Sound connection confusion!!
Discussion in 'Televisions' started by Shady Deal, Feb 19, 2003.
  1. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Have a 46wh08b RP. very pleased with it and my AV connections are as follows:-
    AV1 = RGB SKY Box
    AV2 = S-Video Sony DVD Player
    AV3 = Composite VCR
    AV4 = Componet connection to XBOX (Microsoft genuine Lead)
    My problem is with the optical/co-axial sound inputs. At the moment my Xbox is using the optical input and I have to mess about to plug the cable into the DVD player when I use it.
    So I bought a co-axial lead to go from the DVD to the TV as there are both ttype of sound inputs on the back.
    This has caused a problem!! As soon as I plug the Co-axial lead into the TV it disables the optical input!! Even just plugging tthe lead in and not connecting to anything does the same!! it's as though the TV has a setting that seems to be co-axial takes priority over optical.
    a) Has anyone any idea how I can get this feature turned off??
    b) Any further suggestions on how i can get around this??
    P.S. I can only speak for Tosh RP but the picture from component is amazing even compared to RGB. Would recommend anyone with an X-box to get the genuine lead from USA. You won't be dissappointed!!
    Thanks for any help
  2. vegnomeat
    vegnomeat
    with the tosh42wt29 you had to tell the set which digital audio input was attached to which scart input,
    ie av3 uses optical input
    av1 uses co ax input
    its on the set up menu and quite easy to set
    Wayne
  3. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    On mine you don't have the choice, you just have a option saying "Digital Input - Source"
    I do not have the choice of what digital connection goes to what scart, just one digital "Global" connection to one scart?
