450 katmai good enuf for HTPC duties?
Discussion in 'Desktop & Laptop Computers Forum' started by Simon55, Jan 18, 2002.
  1. Simon55
    Simon55
    I have a few rigs here, but they are all noisy beasts and obviously arnt suitable for HTPC purposes as they are a massive distraction.
    The pc would be used for Playing videos and sky thru an input board using Dscaler, also playing DVD's via power dvd 4 deluxe and also some divx movie files (dl's off the net)
    Just wondering if you lot reccon an old 450 katmai would handle it? (it can do 504mhz if necessary but the plan was to keep this machine passively cooled)
  2. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Simon,
    For Dscaler you really need a PC with much more than 450Mhz.
    If you are going to build one, I would say a P3 1 Gig, or a Celeron 1.2 Gig, on an Asus TUS series motherboard, as the minimum these days.
    It's just not worth larking around with something old and slow, unless you have lots of patience and time.
    Good luck,
    Mark G.
