43MXE1 or 42PHD7?
Discussion in 'Plasma TVs Forum' started by Likvid, Jan 5, 2005.
  1. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    I am torned between these two now.
    I will buy a suitable scaler like Iscan HD+ to it or similar, maybe Lumagen if funds allows it.
    What screen would you recommend and what are the pros and cons of both panels?
    I have read the usermanual for the 43MXE1 but i can't see any mentioning about support for 720p/50Hz or 1080i/50Hz, however the 60Hz signals are listed.
    As my DVD player is outputting the above signals i need to have a panel that supports it and where i won't notice any judder and such.
    I really need some help regarding this as i am bit confused with all incompatiblity all over.....
  2. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    I have read on here that the 43MXE1 has no HDCP support(so Sky HD will be a problem) For the 42PHD7, the card does not support 50hz as you have listed. The new XR3 NEC might and new cards for the other two may come out to fix, but this is not clear yet.
  3. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    There is supposedly a 3rd party board coming out to get round the HDCP problem on the MXE1, but it i wouldnt hold your breath.
  4. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    I've heard that the MXE1 is better built than the Pannys, industrial quality?
    Someone care to comment on that?
