43MXE1 and Scaler
soiaf
I see a few people here have got their 50MXE1 working with a scaler, and are getting great results.
I have a 43MXE1 and I've started trying to get the exact 1:1 mapping with my scaler (a Crystalio) - chancing my arm I tried entering the [email protected] settings that people are using on their 50MXE1s, but that doesn't seem to work out - for example 1344 is the value suggested for horizontal total, but it seems to me (after some experimentation) that 1340 is a better value on the 43MXE1 [though I could easily be wrong here! ].
I'm not too surprised that there seems to be differences, the 50MXE1 does have a larger native resolution.
Is anyone using a 43MXE1 with a scaler? Any advice/suggestions on settings (just looking for some pointers, but if you happen to have the full settings that would be nice :D )
And as an aside question - In the tech specs for both the 50MXE1 and the 43MXE1, in the table giving available resolutions etc., they have a remarks column, for the [email protected] setting they have the remark 1376x768. Anyone know what this means?
Thanks!
soiaf
I've seen them already, sorry.
I know that they work great on a 50MXE1, but they don't seem to work right (for me at least) on the 43MXE1 (yes, I have set the plasma to FRC 2).
Thanks though!
oliverlim
Thanks though!
Hmm...these are for the 43mxe1. I know it works as I just tried it last weekend on a 43mxe1 at my dealers demo room.
What do you mean that it does not work right?
Oliver
soiaf
If I enter the values into the Crystalio, I get a picture no problem etc.
The plasma displays 'dot by dot' - so its happy enough resolution wise.
However, if I test the resolution by using the supplied 'Pixel Magic' disc (various resolution tests) and look at their 'v-line 50' test it doesn't look right - this is basically just a screen with an alternating set of black/white vertical lines.
With the horizontal totals in that attached document (1344) I can basically see a couple of areas of bunched lines (like thick 'bands' going down the screen). But at 1340 I don't see any 'bands' going down the screen.
If you've used these settings on a 43MXE1, thats great news, indicates that theres some other issue.
Are there any setting changes that you know need to be done on the plasma (I think its in factory default mode from a settings perspective)?
Or is there any other setting that you think might be causing an issue?
Thanks a lot for this information.
loonatic
The timing data posted above is direct from Pioneer and works just fine on both 43MXE1s and 50MXE1s via both Lumagen DVI/HDP scalers and HTPCs so I can only assume that the Crystalio is doing something different...have you tried asking on the PMS forum ?
Cheers, Lee
soiaf
Thanks Lee, I'll put a post on the PMS forum about it now.
For my own sanity :) when you press 'Display' on the Pioneer remote using these settings what does the Pioneer show as being its input H & V ?
Thanks again for confirming these
loonatic
Well I have mine set for 1280x768 @ 50Hz and the display reports it back as fH 40.1kHz and fV 50.0Hz with the resolution as 1280x768...with my Lumagen I have to go into the Integrator menu and shift the image position one pixel to the left to get a 1:1 mapping.
You have selected the correct Signal Format under the setup menu haven't you ? just a thought.
Cheers, Lee
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
