43mxe and Iscan - help
Discussion in 'Plasma TVs Forum' started by imclueless, Mar 2, 2005.
  1. imclueless
    imclueless
    Well the plasma arrived 4 weeks after my Iscan.
    I plugged the Iscan to Pioneer using a DVI cable set output to DVIP (and DVIV) output format to XGA and ............ nothing.
    Screen works with svideo ouput and analog dsub.
    Is it a faultly cable (from sony computer to sony lcd screen) or something even simpler
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    What iScan? You do know the DVi on MXE is not HDCP so any protected signals (ie HDCP will be blocked)
  3. imclueless
    imclueless
    It is a hd+
    I'm not worried (yet!) about hdcp - but are current dvds protected this way?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    it will translate macrovision up to HDCP (try DVE disc or a home burnt DVD) or another non Macrovision source...(also need to make sure output is DVi-D and compatible with Pio) MAW is the man to ask.........
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Hi there, I'll try an alternative personality this morning, and try to make your day nicer and nicer! You wouldn't happen to be the person who asked me for a quote would you? You need to set the iscan to dvi-p, xga, and if nothing at 50Hz, go to FRC, unlock 50 Hz and try 75. there are no other reasons why you wouldn't get a picture. They can be funny if you have put the screen into FRC mode 2, but otherwise, this is the most straightforward iscan setup in the known plasma universe.
  6. imclueless
    imclueless
    Hi MAW,
    'Fraid so I was that man -
    You might get some business to do an install if this doesn't work
    Thx
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Thought so. Never mind, and how long did you wait for the plasma? Seems 1/2 a lifetime ago. How far off the M4 are you? I'm passing on Saturday, my wife will kill you though.
  8. imclueless
    imclueless
    After our almost deal I ordered the screen from our IT supplier the same day. Finally got it last Friday so about 4 weeks!
    I live a mile away from the Brynglas Tunnels - I might even have a new stand then!
  9. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Wot planet are they on? I've had about 10 through my hands in the intervening, and I daresay so has Joe and Alastair... If you are still stuck, give me a ring. And get the coffee on. It would be about 0930 I'd guess. Will be mob handed, on way to in-laws.
  10. imclueless
    imclueless
    Bummer - I won't be there that early as I am up in sunny Evesham until late am early pm.
    You could use me as a reason to leave her with her folks later on though!
  11. imclueless
    imclueless
    Came home plugged it all back in and it works! Changed nothing
    Thx for the offer of assistance though and might get you to do a pro install later in the year if that's possible
    Regards
    Ian
  12. stricko
    stricko
    Jan 20, 2004
    293
    Lambourn
    +6
    About to set off down the HD+ route so interested in the thread...
    I have an old school PDP433MXE panel; will the settings you are suggesting for the 43MXE(1?) be the same for me also?
    Many thanks (in anticipation)
  13. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Don't see why not, except for frame rate. You will need to go 50 to 60 Hz conversion. This will leave you with some judder, perhaps you should have a look at an MXE forced into this mode before going DVI. If you don't like it on DVI it will of course work on VGA perfectly well, with seriously excellent results. It's possible to get too hung up on digital video, it's not always the ultimate.
  14. stricko
    stricko
    Jan 20, 2004
    293
    Lambourn
    +6
    I'll be able to run DVI and VGA side by side (even with the current wiring!) so I'll be interested to see the comparison.
    While I'm on, a quick HD+ query. Is the AV Lip sync setting manually adjustable per input channel or is it a single value. I'm assuming that the HD+ will automatically adjust for each processing path, I can set a manual increase or decrease to compensate for the plasma (if necessary), but what if my input sources have different audio delay characteristics.
    And finally, (honest) Am I right in assuming that the HD+ will output optical digital audio if the input is coax (and vice versa). The manual suggests this, but the wording is a little ambiguous.
    Once again, many thanks
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There are 2 optical and 2 digital inputs, individually assignable to any video input, and yes, both optical and coaxial outputs are active whatever the input. Each audio input is adjustable independently for audio delay. Good device, simple to use.
  16. stricko
    stricko
    Jan 20, 2004
    293
    Lambourn
    +6
    Brilliant, just what I wanted to hear.
