436XDE & xBox 360 - sound.
Discussion in 'Plasma TVs Forum' started by Reefon, Mar 13, 2006.
  1. Reefon
    Reefon
    Hi all,
    Is there a way I can get an audio signal from my 360 to my TV (436 XDE) with the 'premium cable' alone? Or do I need an optical cable?
    Thanks in advance. :)
  2. thowal
    thowal
    Connect the 2 audio connectors to the scart adapter and put it in scart 2, then you can get the picture from component and sound from the scart.
  3. Reefon
    Reefon
    Awesome! Really appreciate the reply mate, and something so simple... cant wait to get home now! :D
  4. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    Palm Jumeirah, Dubai
    +21
    You won't get 720p if going through the SCART inout though, will you?
  5. Reefon
    Reefon
    Even if im using component for video? and just scart for sound? :confused:
  6. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    Ignore me..........I read that the first time as connecting the audio connectors as well as the video into the scart adapter.
    I'll go back into my hole now ! :suicide:
  7. Reefon
    Reefon
    No worries buddy, thanks the reply anyway. :hiya:
    Nearly hometime... :D
  8. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    WHat settings do you have the 360 on? Any chance of taking a look and posting them here? I'm about to get one of these and am in the final retention paranoid state ;)
