436xde tabletop stand
Discussion in 'Plasma TVs Forum' started by DM 73, Oct 28, 2005.
  1. DM 73
    DM 73
    May 10, 2005
    803
    46
    +157
    I'm going to buy a pioneer 436xde in the next few weeks and am looking for info on table top stands that are compatible,model no. prices and best place to buy would be much appreciated :thumbsup:
  2. Sooren
    Sooren
    Sep 25, 2005
    93
    Beccles Suffolk
    +6
    I have a new one that is unused if your interested. Mine came with a wall mount and table top stand. I wall mounted mine.
  3. DM 73
    DM 73
    May 10, 2005
    803
    46
    +157
    what is the model no. for that and how much are you after ? :)
  4. DM 73
    DM 73
    May 10, 2005
    803
    46
    +157
    Does anyone know if the pdk-tso5 pioneer stand will fit the new xde :confused:
  5. Galaxian
    Galaxian
    Oct 4, 2005
    79
    +5
    I was told by a retailer it would fit. This stand is for the older 435 model and the only difference is the screen is not raised high enough to fit the bottom speaker bar (PDP-S39)
    I have the PDK-TS12 as I want to fit the speaker bar underneath rather than have side speakers. The TS12 comes with 2 pairs of speaker mounts, long and short to cater for side or undermount speaker installations.
    Hope this helps.
  6. DM 73
    DM 73
    May 10, 2005
    803
    46
    +157
    Cheers that does help,thanks
    :smashin:
  7. birdseed
    birdseed
    Nov 17, 2004
    229
    +5
    Ah, i was told by plasmawarehouse.co.uk that the reason they didnt have a 436 on display was that they hadnt recieved the new 436 stand and the 435 stands mounts was just out enough not to fit the new model. It might be worth checking with them too!
