436XDE settings after run in period - what are yours?
Discussion in 'Plasma TVs Forum' started by blossom, Oct 23, 2005.
  1. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    Hi guys,
    Interested in peoples settings post running in period, if anyone has run them in yet.
    I am still running the contrast at 10. All other settings at 0. Have probably done 120 + hours by now and feel the need to tweak.
    Still think its the muts nuts by the way.
    Help appreciated.
    Paul
  2. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    cool mate i am due to get mine delivered this week, getting excited now ! any suggestions from out of the box, what settings etc did you do?
  3. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    All I did was turn the contrast down to 10,and left colour, brightness, tint, sharpness etc all at 0. Also turned off all picture processing like DNR and Cinema mode.
  4. birdseed
    birdseed
    Nov 17, 2004
    229
    +5
    oh, ive been running at contrast 24 since it arrived, brightness about -2. I must be about 100hrs ish? but i cant seem to get the clock to run as i cant find the "display" button and the one below 9 as suggested elsewhere doesnt set it off either. I took it out of dynamic though.
  5. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Had mine 4-5 weeks and have just tweaked using AVIA.
    Contrast: 45
    Brightness: -1
    Colour: -8
    Sharpness: -3
    Tint: -1
    DNR: Off
    Pure Cinema: "Standard" when watching SKY (get interlacing without), "ADV" when watching NTSC DVD's (stops judder). PAL DVD's both "Standard" and "ADV" are greyed out.
    DRE: Mid
    Black Level: On
    CTI: On
    100Hz for everything except HDMI (DVD) which is set @75Hz.
    Some people have their contrast set really low (20-35) and brightness high (+8). I have no Idea why, because the blacks wash out and the picture looks really dull using these settings?
  6. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    Do you find the football OK at these settings?
  7. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Absolutely fine, no judder whatsoever. I have noticed that you only really need DNR turned on when watching old broadcast material like 70's and 80's TV shows for example. When watching a DVD or SKY Movies, I can honestly say that DNR makes little or no difference. Pure cinema "ADV" works well with NTSC DVD's (actually stops judder), however, "Standard" makes little difference, but does seem to help with interlacing when watching SKY.
    I noticed 'slight' interlacing to the on screen names/phone numbers fading in and out when watching the X-Factor on Saturday. Turning on Pure Cinema to "Standard" fixed the problem. Pioneer say that Pure cinema is not needed for non-HDMI/Digital sources, as it's processing for analogue sources only. However, I found that it definately helps with NTSC movies on my HDMI player? Confusing I know! :eek:
  8. alwyn
    alwyn
    Dec 10, 2002
    570
    west country
    +13
    Try these settings,they work very well for me
    Contrast 25
    Brightness +8
    Colour -10
    Sharpness -3
  9. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Just out of interest, why are you using such low contrast and high brightness?
    The contrast does not start to bleed on my 436 until I turn it up to around "50". According to my Ovation Software test pattern, the correct setting for contrast is "45". In addition, if you set the brightness too high, your blacks will wash out and appear grey. Again, according to AVIA, the correct setting is "-1". I agree with your other settings, however, your colour seems a little low.
    I know this stuff is personal pref, but your contrast and brightness settings seem way off?
  10. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    1,002
    +82
    I like to turn the sharpness up to 5 on my 506. I have contrast at around 25, brightness at -2 and colour at 0.
    Also I prefer 1125i to 740p (that's what my tv displays them as, as oppose to 1080i and 720p). I don't know why this is.
  11. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    I know what you mean, 720p comes up @750p for some reson on my screen?
    Panzer22 turn your sharpness down, you will definately notice line noise @ +5, somewhere between -5 and 0 should be perfect :thumbsup:
  12. Blade10
    Blade10
    Mremulator: What is this software you calibrated your screen with? Just tried your settings and I find the contrast to be way to high, how can u be satisfired with it that high?
    contrast= 27
    brightness=0
    color= -13
    sharpness = 0
    tint= 0
    DRE: off
    CTI= on
    gamma= 2
    black level= on
    Try these settings, leave you with a more natural picture.
  13. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Ovation Software. There are five blocks (black on the bottom fading through grey to white towards the top) and the correct setting is just before the top 2 blocks bleed into one block (50). So 45 looks perfect according to my setup disc. In addition 2 local specialist dealers have their 436's set up similar to mine.
  14. Blade10
    Blade10
    OK so the gray scale is near perfect?
    What about your Gamma setting, color setting and ACL?
  15. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Ovation provide a blue filter lens to look through when adjusting the colour and tint. I had my colour set @-12 before I ran the setup disc. Anyway, you adjust the colour until the flashing blocks marked "saturation" almost stop flashing and dissapear into the background (-7 or -8 seems perfect). You do exactly the same with tint, only you adjust to the blocks marked "hue" and not "saturation"
    ACL is off and gamma is at factory default "3" I think.
    Anyway, all looks spot on to me. Turning the contrast down to sub 30 makes it look really dull IMHO.
  16. Blade10
    Blade10
    Ok sounds fine! But could you check what the gamma is set to??
    Cause the difference is pretty big, 3 is much brighter than 2...
    Thanks!!
  17. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    Glad your picture looks good to you - that is really all that matters. But just to put my oar in, the "5 blocks" are for setting up CRT displays. They don't work with digital devices which don't "bloom". Your contrast setting is way, way higher than I would expect.
  18. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Gamma is set to "3"
  19. Blade10
    Blade10
    But what about his other settings? Don't they work with plasma displays? color, brightness, sharpness ect..??
    I am going crazy with picture settings, I never seem to be satisfied, changing it every day almost. Too brigt, to dark, dre on or off ect ect ect...:((
  20. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    I've been reading about you guys, I will gladly bow down to your knowledge and would really appreciate your help. Arcam sent me the disc and I have spent hours mucking about with it, much to my wifes displeasure :clap:
    Anyway, today I got a little worried when I saw most people posting their settings with a contrast level of sub 30. I think that everything looks a little dull below 40, and 30 seems really off to me.
    I thought that these screens were meant to be used with a high contrast setting? Now I'm really confused :rolleyes:
  21. Blade10
    Blade10
    So how should the contrast be set?
  22. Blade10
    Blade10
    After tweaking a little I found that my HDMI picture is a lot better with the following settings:
    contrast= 27
    brightness= -1
    color= -12
    sharpness= 0 (or -3)
    tint= 0
    CTI= ON
    DRE= OFF
    Black level= ON
    ACL= OFF
    GAMMA= 3
  23. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    I really wish there was some sort of guide for this. I agree with you Blade about the colour being set to -13, however, my setup disc and filter says otherwise.
    But the contrast still seems way too dull @ 27 and I now think 45 is too high, So would 35 be ok. When I say "ok" I mean would that be considered right?
    And what about pure cinema etc etc?
  24. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    The right test pattern for contrast is on title 13 (not title 12) of DVE when calibrating fixed pixel displays. I am not going to give away any more "trade secrets" - we calibrators have a living to earn!
    Blade,
    You are on the right lines with your current settings!
    mremulator,
    I do calibration for a living. I share many of my tricks, but there comes the point when I have to say get it calibrated by a pro. Your current settings are way out, and can be made hugely better - I am not allowed to say by me!
    There are a couple of ISF calibrators who have banner adverts on this forum - these banners cost them, but finance the forum - check these adverts and my signature below!
  25. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    ? Only my contrast setting is different really. If my settings are way off, then that disc Arcam supplied is not much use to man nor beast then is it :mad:
  26. alwyn
    alwyn
    Dec 10, 2002
    570
    west country
    +13
  27. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
  28. alwyn
    alwyn
    Dec 10, 2002
    570
    west country
    +13
    Lets hope you are able to state what the ISF settings for the basic contrast,brightness and colour are that info will be of interest to us all I am sure
  29. Blade10
    Blade10
    Yes Mremulator, let us know when Gordon is finished setting up your screen!
    Also, I am curious to hear how different the picture will be, cause honestly, I think you will have to get used to a less contrasty picture. (With current 45 in contrast).
    Your settings will look more like mine I think. The goal is to get a natural picture.
  30. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Blade10, I'll post my results tonight. However, last night I turned off DRE which made quite a difference. My contrast is currently set @32, brightness -1, colour -10, sharpness -3 & tint -1. Pure Cinema is off, ACL is off and DNR is off.
    Just to let you know that I've been told that the pioneers end up with a contrast setting of between 30 and 32 once they have been calibrated. But don't tell everyone :devil:
