436xde picture quality
Discussion in 'Plasma TVs Forum' started by alantemperton, Aug 6, 2006.
  1. alantemperton
    alantemperton
    Aug 6, 2006
    23
    3
    I have just purchased a pioneer 436 xde and am disappointed with the grainy picture. Colurs are rich and vibrant but overall grainy picture. I live in an apartment with a communal sky dish. I do not subscribe to Sky for a picture and can only view the free channels. Looking at the sky box system set up - signal strength is weak on the bar barely at 5-10% but the quality of the signal is at 70%. I have not changed any of the plasma default settings. I am using top quality gold connector scart leads.
    Your advice on settings etc would be appreciated
  2. monkeylala
    monkeylala
    Sep 17, 2005
    82
    11
    Poulton Le Fylde
    +7
    If you do a search under 436xde in this forum you will find all the info you need about seetings for your new plasma. Cheers
  3. Dave
    Dave
    Jul 3, 2005
    11,496
    163
    +3,401
    You can't polish a turd.:rolleyes:
    Unfortunately if you feed the screen a poor signal, you get poor pq and though fiddling with the settings may help it'll never be great.
  4. yorkyred
    yorkyred
    Oct 30, 2005
    373
    +39
    Sadly true. Nothing is going to help short of moving.
  5. chaparral
    chaparral
    Apr 8, 2006
    2,041
    Planet Earth
    +426
    You have the sky outputting RGB throught the scart cable and the 436xde set to RGB on that scart input ?? very important you do this..
    Plus your not sitting to close to the screen..(I.E nothing under about 9ft min..about 10ft to 12ft away for SD on a 43" screen would be about right )
