436xde - noises when starting up and closing down
Discussion in 'Plasma TVs Forum' started by Juddy, Mar 17, 2006.
  1. Juddy
    Juddy
    Had my 436xde for about two weeks. When turning on in the mornings and turning off at night, it makes a kinda chirping noise from the right hand back of the screen, as if something is warming up, or cooling down when I turn off. It goes after a minute or two. Any thoughts ? (And no jokes about the budgie getting in the set!!!) Is this normal ??
  2. weezer
    weezer
    Mine does to, seems to be a feature :).
  3. Steve_B
    Steve_B
    Oct 23, 2004
    2,898
    Somewhere near Alpha Centuri
    +112
    Yep my 506 does the same, a fizzy chirp then a click which is a relay flicking open\closed... probably a power circuit building up charge?
  4. Juddy
    Juddy
    Thanks guys. Appreciate your replys. Comforting to know that it's not just mine then. Releif! :)
  5. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    my 436 doesnt chirp but it certainly clicks when turning off/on
